DUAL-LAPTOP KVM DOCK: connect / toggle between 2 PCs on your desktop and share 2 4K 60Hz displays, keyboard, mouse and other USB peripherals; toggle between two laptops using a toggle button on the front of the dock.
SIMULTANEOUSLY CHARGE TWO LAPTOP COMPUTERS: The USB-C KVM dock charges the 2 PCs connected via USB-C (PD 3.0); The included 180W power adapter automatically provides 90W of power to the active host and 45W of power to the standby host.
GUARANTEED COMPATIBILITY: DisplayLink-certified dual-host KVM dock supports 2x displays on MacBooks M1/M2; Works with mixed OS (Win/MacOS/Chrome OS); Works with PC USB-C, TB4/3, USB-A (USB-C to A cable not included).
CONNECTIVITY: The dock features a variety of ports for device connectivity; 2x USB 2.0 Type-A HID/2x USB-A (10Gbps)/USB-C (10Gbps)/2x DisplayPort/2x USB-C/Gigabit Ethernet/audio stereo 3.5mm/micro 3.5mm host ports/2x K-Slots (Standard/Nano).
OUR ADVANTAGE: Connectivity tools included for IT pros and IT teams with Network MAC Address Pass-Through for network security, WiFi Auto Switching to improve network performance/USB Event Monitoring/Windows Layout.
DisplayLink Certified
The Dock is DisplayLink Certified, for Plug and Display compatibility with Windows, ChromeOS, and macOS, enabling operation and switching between multiple computers with different operating systems. DisplayLink technology also supports extended dual displays on base Apple M-Series MacBooks, which are not natively capable of driving more than one external display. The DisplayLink Certification ensures support for resolutions up to 4K 60Hz on both external displays. -
Simultaneously Charge Two Laptops
The KVM Dock supports Power Delivery (PD) 3.0 and charges both connected computers over USB-C. The Dock supplies 90W of power to the active host computer and 45W of power to the second PC, ensuring both laptops can charge simultaneously. -
Full-Featured Docking Station
Connect two USB-C computers to this Dock to access a wide range of port connectivity, options and features. The Dock features: • 2x DisplayPort ports for dual display output with support for resolutions up to dual 4K 60Hz. • 2x USB-A (USB 2.0 480Mbps) HID ports for USB devices, such as a keyboard and mouse. • 2x USB-A and 1x USB-C (USB 3.2 Gen 2 10Gbps) ports for connecting high speed USB peripherals, such as SSD storage. • 1x Gigabit Ethernet port with WoL (Wake-on-LAN) for a wired Local Area Network (LAN) connection. • 1x 3.5mm 3-position TRRS jack for stereo audio output. • 1x 3.5mm 2-position microphone jack for mono audio input. • 2x K-Slots (regular/nano) to tether the Dock with a cable lock (sold separately) for security. The Dock features a mounting pattern so it can be mounted when paired with StarTech.com mounting accessories (sold separately). Our mounting accessories enable mounting to the VESA pattern on the back of a monitor or to any flat surface. The following mounts are compatible with this product: • SSPMSUDWM - Dock Surface Mount • SSPMSVESA - Dock VESA Mount -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable users to quickly access faster network speeds via wired LAN. Linux users will not have access to the following software features: • Set Laptop Screen Location for Mouse Cursor/Keyboard Edge Scrolling. • Switch UFP (Upstream Facing Port). • Ctrl-Alt-Del Functionality. • Change Hot-Key for Switching. • KM Master for Mouse Cursor/Keyboard Edge Scrolling.
- StarTech.com Dual-Laptop USB-C KVM Docking Station, Dual Monitor 4K 60Hz DisplayPort Dock, 5-Port USB Hub, GbE, 90W/45W Power Delivery to Two Laptops, Windows/Mac, 2-Host KVM Dock - docking station - USB-C 3.2 Gen 2 - 2 x DP - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C 3.2 Gen 2
- Video Interfaces
- 2 x DP
- 9 cm x 22.4 cm x 4 cm
- 402 g
- Localisation
- Europe, United Kingdom
- Networking
- Gigabit Ethernet
- Power
- Power adapter 180 Watt AC 100-240 V (DC 20 V)
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 9 cm
- 22.4 cm
- 4 cm
- 402 g
- Localisation
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3ab, IEEE 802.3u
- 2 x USB 2.0 - 4 pin USB Type A , 2 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x microphone - mini-phone 3.5 mm , 1 x headphones - mini-phone 3.5 mm , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB-C 3.2 Gen 2 with Power Delivery 3.0 - 24 pin USB-C
- Cables Included
- 2 x USB-C cable - external - 1 m
- Dual display support, security lock slot (cable lock sold separately), LED indicator, up to 10Gbps data transfer, full duplex support, host selection button, plastic housing, dual KVM host devices, 90W power delivery for active host device, 45W power delivery for standby host device, MAC address pass-through
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- DisplayPort 1.4, USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), RoHS, WEEE, DisplayLink certified
- TAA Compliant
- Power Device
- Power adapter
- Power Consumption (Max)
- 180 Watt
- Voltage Required
- AC 100-240 V
- Voltage Provided
- DC 20 V
- OS Required
- Apple macOS Monterey 12.0, Apple macOS Big Sur 11.0, Apple macOS Catalina 10.15, Apple macOS Sonoma 14.0, Apple macOS Ventura 13.0, Google Chrome OS, Microsoft Windows 10 / 11, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04
- Limited warranty - 3 years
- Shipping Width
- 16 cm
- Shipping Depth
- 28.5 cm
- Shipping Height
- 9 cm
- Shipping Weight
- 1.8 kg
- -10 °C
- 45 °C
StarTech.com USB-C KVM Docking Station
