StarTech.com USB-C Headphone Splitter
Quicklinx: H1T9WS00 Mfr#: USBC-AUDIO-SPLITTER
Length: 7cm
39 In Stock
£19.52 ex VAT
£23.42 inc VAT
This USB Type-C Headphone Splitter enables two 3.5mm audio connections. The 3.5mm ports accept 4-pole 3.5mm TRRS connectors and support simultaneous stereo audio output and headset/microphone input. The adapter also features an integrated 2.75in (7cm) USB-C cable.
  • Headset Mic/Stereo Audio Control on the 3.5mm Ports
    Connect two headsets to the same USB-C port. Microphone input is supported across both headsets, offering a convenient solution for team training and conferencing calls. The adapter supports dual CTIA or dual OMTP headset types allowing universal compatibility.
  • Lossless Audio with High-Impedance Headphones
    The USB-C headset dongle features built-in 24-bit Digital to Analog Converter (DAC). The DAC supports a sampling rate of up to 192kHz for uncompromising quality and performance.
  • Compact USB-C Audio Adapter
    The USB-C to dual-audio adapter is small and lightweight, perfect for professionals who are frequently on the go. It is the ideal solution for adding two 3.5mm audio jacks to a USB-C device. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com USB-C Headphone Splitter, USB Type C Dual Headset Adapter w/Microphone Input, USB C to 3.5mm Adapter/Earphone Dongle, USB C to Audio Jack/Aux Output - Mic and Headset Controls, Built-in 24-bit DAC (USBC-AUDIO-SPLITTER) - audio splitter - 7 cm
Cable
Audio splitter
Length
7 cm
Black, space grey
Connector
24 pin USB-C - male - straight
Connector (Second End)
2 x mini jack - female - straight
USB / USB 2.0
Outer diameter 3.2 mm, built-in digital to analogue converter (DAC), strain relief
Cable Type
Audio splitter
Jacket Material
Thermoplastic elastomer (TPE)
USB / USB 2.0
Length
7 cm
Plated Connector
Aluminium
Black, space grey
Connector
2 x mini-phone 3.5 mm - female - straight
RoHS, FCC, WEEE
Shipping Width
12.5 cm
Shipping Depth
9 cm
Shipping Height
0.82 cm
Shipping Weight
20 g
Limited warranty - 2 years , Technical support - lifetime
Length: 7cm
