StarTech.com USB-C GbE Adapter + 3-Port Hub
Quicklinx: CTW7WS00 Mfr#: US1GC303APD
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: [N/A]
Compatibility: Unix, Mac, PC
Type: Network adapter
£43.71 ex VAT
£52.45 inc VAT
Connect to a GbE network plus add three USB Type-A ports and PD Charging through your laptop's USB-C port. Add powerful connectivity to your USB-C enabled laptop, tablet or desktop computer. Ideal for mobile use, this USB-C to Ethernet adapter plugs into your USB-C or Thunderbolt 3 port to provide wired network access, and gives you three USB 3.0 Type-A ports to connect your peripheral devices. Plus you can charge your laptop as you work. It makes a great companion for your MacBook, Chromebook Pixel, Dell XPS 12, or other device.
Gain a wired internet connection virtually anywhere you go. The USB-C network adapter provides an Ethernet port that supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps), also known as USB 3.1 Gen 1. You can connect to a network in locations where Wi-Fi is unavailable or unreliable, and quickly access large files over the network at Gigabit speed.
Some USB Type-C laptops, tablets and computers have only one port for external connectivity, which limits the number of peripheral devices you can use. This USB-C Ethernet adapter features a built-in hub with three USB Type-A ports, giving you the freedom to attach additional devices, such as a USB mouse or flash drive. You can expand the number of USB ports you have to enhance your productivity.
Travel-sized and self-powered, this USB-C network adapter and hub provides easy portability, tucking easily into your laptop bag and eliminating the need to carry a separate Gigabit Ethernet adapter and USB-C to USB-A hub. It's ideal for mobile use, providing you with wired network connectivity wherever you go, and letting you plug in extra USB peripheral devices. It also has a built-in USB-Type-C cable so it's always there when you need it.
The USB-C network adapter lets you power and charge your laptop as you work, while powering the hub at the same time. The adapter supports Power Delivery 2.0, so instead of carrying multiple power adapters, you can use your laptop's USB-C power adapter to power both your laptop and network adapter. Note: just make sure your laptop's USB-C based power adapter supports USB Power Delivery 2.0.
Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. It automatically installs once you connect it, and works with a wide range of operating systems such as Windows, macOS, Linux and Chrome OS.
  • Access reliable Gigabit network connections
  • Enhance productivity with a 3-port USB hub
  • Gain easy portability
  • Power and charge as you work
  • Install it with ease
    Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. It automatically installs once you connect it, and works with a wide range of operating systems such as Windows , macOS, Linux and Chrome OS . The US1GC303APD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to Ethernet Adapter - 3 Port - with Power Delivery (USB PD) - Power Pass Through Charging - USB C Adapter (US1GC303APD) - network adapter - USB-C - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
USB-C
Ports
Gigabit Ethernet
4.1 cm x 9.5 cm x 1.7 cm
44.9 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
5 Gbps
Jumbo frame size: 9000
VL100 / VL813 / RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
5 Gbps
Full duplex capability, auto-negotiation, USB powered, Jumbo Frames support, plastic housing, Energy Efficient Ethernet, UASP, built-in 3-port USB 3.0 hub, VLAN Tagging (not supported in MacOS)
Processor / Memory
1 x 1000Base-T - RJ-45 - female , 3 x USB 3.0 - 9 pin USB Type A - female , 1 x USB-C - 24 pin USB-C (power only) - female
FCC, RoHS, WEEE, RCM
4.1 cm
9.5 cm
1.7 cm
44.9 g
45 °C
10 - 90% (non-condensing)
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Form Factor: [N/A]
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
