USB-C to Network Adapter 10/100/1000Mbps Thunderbolt 3 Compatible RJ45. This USB-C Ethernet adapter connects you to a Gigabit network through the USB-C or Thunderbolt 3 port on your laptop or desktop computer and adds connectivity for an additional USB (Type-A) peripheral device. It's a great companion for your MacBook, Chromebook or Windows laptop with an available USB-C port.
Powerful Gigabit Network Connections
The USB-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1. You can quickly access very large files over the network at Gigabit speed.
Native Driver Support Makes Installation Easy
Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. The network adapter chipset provides native driver support in Chrome OS , Windows , and macOS.
Trouble-Free Connections Through USB-Type-C
The USB-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up, without frustration or the risk of port damage.
With a compact design, this USB-C network adapter is as portable as your laptop, perfect for ultra-portable devices that have a USB-C port, such as the MacBook and Chromebook Pixel . The network adapter is bus-powered which makes it easy to connect when you're on the go.
Additional Connectivity With an Extra USB 3.1 port
Some computers with USB Type-C only offer one port for external connectivity. This Ethernet adapter features a built-in USB Type-A port, giving you the freedom to attach an additional peripheral device, such as a USB mouse.
The US1GC301AUW is backed by a StarTech.com 2-year warranty and free lifetime technical support.
The USB-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1. You can quickly access very large files over the network at Gigabit speed. -
Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. The network adapter chipset provides native driver support in Chrome OS , Windows , and macOS. -
The USB-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up, without frustration or the risk of port damage. With a compact design, this USB-C network adapter is as portable as your laptop, perfect for ultra-portable devices that have a USB-C port, such as the MacBook and Chromebook Pixel . The network adapter is bus-powered which makes it easy to connect when you're on the go. -
Some computers with USB Type-C only offer one port for external connectivity. This Ethernet adapter features a built-in USB Type-A port, giving you the freedom to attach an additional peripheral device, such as a USB mouse. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB C to Gigabit Ethernet Adapter with USB A Port, White 1Gbps NIC USB 3.0/USB 3.1 Type C Network Adapter, 1GbE USB-C RJ45/LAN TB3 Compatible Windows MacBook Pro Chromebook - USB C to Ethernet (US1GC301AUW) - network adapter - USB-C - Gigabit Ethernet + USB 3.1 Gen 2
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- 3.5 cm 1.7 cm
- Length
- 27.5 cm
- 38 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.1
- White
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Google Chrome OS, Microsoft Windows Server 2012, Linux Kernel 2.6.25 or later, Apple MacOS X 10.11 - 10.14, Linux LTS versions only, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-C
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, plastic housing, Energy Efficient Ethernet
- 1 x 1000Base-T - RJ-45 - female , 1 x USB 3.1 Gen 1 - 9 pin USB Type A - female
- Cables Included
- USB-C cable (integrated) - 20.3 cm
- FCC, RoHS, WEEE, REACH
- White
- OS Required
- 3.5 cm
- 1.7 cm
- Length
- 27.5 cm
- 38 g
- Shipping Width
- 14.3 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 92 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 80%
StarTech.com USB-C to Gigabit Adapter | In Stock | £41.55 |
StarTech.com USB-C to Ethernet Adapter | In Stock | £27.36 |
