StarTech.com USB C Dual HDMI MST HUB 4K
Quicklinx: GTBMWS00 Mfr#: MST14CD122HD
19 In Stock
£24.45 ex VAT
£29.34 inc VAT
This USB-C to HDMI MST Hub allows you to connect two HDMI monitors, using a USB-C enabled host device.
  • Multi-tasking Made Easy
    This USB-C to HDMI video splitter connects up to two additional displays in extended or mirror mode. Connecting two independent 4K 60Hz displays creates high-performance workstations, for users in your organization enabling easier multi-tasking resulting in increased productivity.
  • 4K at 60Hz and HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single signal/stream. This MST Hub separates the single stream into two independent signals, one for each HDMI enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Hassle-Free Setup
    Windows devices that support DP Alt Mode over USB-C feature native support for MST. This USB-C to HDMI hub is compatible with Thunderbolt 4, Thunderbolt 3, and USB4 enabled Windows devices. Plug-and-play installation with no drivers or software required. The 12in (30cm) attached cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is bus-powered, meaning no external power is required. MST14CD122HD is backed by a StarTech.com 3-year warranty, and free lifetime multilingual, North American based technical support.
StarTech.com USB-C to Dual HDMI MST HUB, Dual HDMI 4K 60Hz, USB Type C Multi Monitor Adapter for Laptop w/ 1ft (30cm) cable, DP 1.4 Multi-Stream Transport Hub, USB Type C to 2x HDMI Ports - USB-C to HDMI Splitter (MST14CD122HD) - adapter - DisplayPort / HDMI
Cable
Adapter - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 60 Hz
Grey
Connector
24 pin USB-C - male
Connector (Second End)
2 x HDMI - female
DisplayPort 1.4
Display Stream Compression (DSC), HBR3 audio support, Multi Stream Transport (MST), 7.1 channel Surround Sound, DisplayPort Alternate Mode support
3-year warranty
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
DisplayPort 1.4
Grey
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Microsoft Windows 10 / 11
Connector
24 pin USB-C - male
2 x 19 pin HDMI Type A - female
RoHS
10.5 cm
4.3 cm
1.4 cm
55 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
110 g
Limited warranty - 3 years
GTBM StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
GTBM StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.69
GTBM StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GTBM StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £18.52
GTBM StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet In Stock £15.69
GTBM StarTech.com 3-Port USB-C MST Hub, 4K 60Hz In Stock £29.54
GTBM StarTech.com 2-Port USB-C MST Hub, 4K 60Hz In Stock £25.08
