Connect a USB Type-C/Thunderbolt 3/4 enabled Chromebook and a combination of DisplayPort and HDMI monitors to this USB-C Docking Station. This dock supports Chromebooks and Ultra HD 4K monitors. The 3.3ft (1m) USB-C Screw Lock to USB-C Cable ensures a secure connection to the dock and host device.
Works with Chromebook (WWCB) certified
This USB-C Docking Station is tested and certified to meet Google Chromebook compatibility standards. The certification ensures seamless operation with Chromebook devices. This is the ideal dock to deploy in Google Chromebook enabled business environments. Automatic firmware updates are available through ChromeOS for maximum security, compatibility, and performance. -
Enhance Productivity with Triple-4K Video
Connect a combination of one USB-C DP Alt Mode, one HDMI, and/or up to two DisplayPort monitors to the Video 1 and Video 2 Ports and connect one HDMI monitor to the Video 3 Port for a triple-monitor setup at 4K 30Hz, and features up to 4K 60Hz. High-resolution video performance is vital for applications involving detailed graphics, enhancing workplace productivity?by expanding the display capabilities of Chromebook devices. -
Chromebook Docking Station Features
Connect the docking station to a Chromebook's USB Type-C/Thunderbolt 3/4 port to enable a variety of connectivity options and features. • 3x USB 3.2 Gen 2 (10 Gbps) Type-A - one 1.5A charging port • 2x USB 2.0 (480 Mbps) ports for USB-peripheral devices • 2x USB 3.2 Gen 2 (10 Gbps) Type-C data and 1.5A charging port, Video 1 Port (DP Alt Mode) • 1x Gigabit Ethernet port • 1x 3.5mm Audio Jack 4-pole TRRS for a 3.5mm headset • 2x Kensington Security Lock Slots -
60W USB Power Delivery 3.0
The USB-C Docking Station supports 60W USB Power Delivery, using the universal power adapter. This product is backed for 3-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance. This product works with devices capable of running the latest version of ChromeOS and has been certified to meet Google's compatibility standards. Google is not responsible for the operation of this product or its compliance with safety requirements. Chromebook and the Works With Chromebook badge are trademarks of Google LLC.
- StarTech.com USB-C Docking Station - Multi Monitor HDMI/DP/DP Alt Mode USB-C Dock - 3x 4K30 / 2x 4K60 - 7-Port USB Hub - 60W Power Delivery - GbE - 3.5mm Audio - Works With Chromebook certified - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI, 2 x DP, USB-C - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- 21 cm x 8 cm x 3.2 cm
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100-240 V 60 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 21 cm
- 8 cm
- 3.2 cm
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz , 5K - 60 Hz (Single Display (DisplayPort 1.4 HBR3 with DSC)) , 4K - 60 Hz (Dual Display) , 4K - 30 Hz (Triple Display)
- Data Link Protocol
- USB 2.0, USB 3.1, USB 3.2 Gen 2
- 2 x display / video - HDMI output - 19 pin HDMI Type A , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB-C 3.2 Gen 2/DisplayPort - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB 3.2 Gen 2 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x headphone/microphone combo jack - mini-phone stereo 3.5 mm 4-pole , 1 x USB-C 3.2 Gen 2 with Power Delivery 3.0 - 24 pin USB-C
- Cables Included
- 1 x USB-C screw-lock cable - detachable - 1 m
- Firmware upgradable, Preboot Execution Environment (PXE) support, mounting holes, kensington security slot, 4K Ultra HD, MST (multi-stream transport), DisplayPort Alt Mode, one-touch power button, triple display support, power LED status
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- FCC Part 15, FCC, RoHS, WEEE, RCM, DisplayPort 1.4, USB Power Delivery 3.0, UKCA, Works With Chromebook (WWCB) certified
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V
- Power Provided
- 60 Watt
- OS Required
- Google Chrome OS
- Limited warranty - 3 years , Technical support - assistance - lifetime
- 0 °C
- 40 °C
