StarTech.com USB C Dock, Triple 4K Monitor USB Type C Docking Station
Quicklinx: GBT9WS00 Mfr#: DK31C2DHSPDUE
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
30 In Stock
£120.07 ex VAT
£144.08 inc VAT
USB Type-C Multiport Adapter - Triple 4K with DP 1.4 & HDMI 2.0 - 100W PD - 6x Downstream USB Ports
This USB-C Gen 2 10Gbps docking station turns your USB-C or Thunderbolt 3 Windows laptop or Chromebook into a powerful workstation. A USB 3.2 Gen 2 Type-C dock features everything you need, from triple video outputs up to 4K 60Hz to 10Gbps USB-C & USB-A downstream peripheral ports to 100W Power Delivery.
HDMI & DisplayPort for Multiple Monitor Outputs
This USB-C Gen 2 docking station with DP 1.4 and HDMI 2.0 HBR3 support, is a perfect choice for dual or triple monitor setup, supporting up to triple 4K 30Hz nearly uncompressed video resolution output , with two DisplayPort and one HDMI outputs. Maximum dual and triple 4K display performance is supported on USB-C 11th Gen Intel-based (DP 1.4 HBR3 with DSC support) Windows Thunderbolt 3 or USB-C laptops, but backwards compatibility to older laptop generations and lower resolution monitor requirements.
DP 1.4 HBR3 with DSC Enabled
DP 1.4 HBR3 (without DSC)
DP 1.2 HBR2
Triple Display
Up to 4096 x 2160 @ 30Hz
Up to 1920 x 1080 @ 60Hz
Up to 1600 x 900 @ 60Hz
Dual Display
Up to 4096 x 2160 @ 60Hz*
*HDMI port + DP port or 2 DP ports
Up to 2560 x 1440 @ 60Hz
Single Display
Up to 3840 x 2160 @ 60Hz
Up to 3840 x 2160 @ 30Hz
Power & Charge with 100W Power Delivery
Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 100 watt power delivery, to keep high performance laptops sufficiently charged during heavy productivity usage.
Charge smartphones and other devices with USB-C downstream charging ports featuring BC 1.2 charging specification. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected.
Integrated 6-Port USB Hub & SD Card Reader
This USB-C Gen 2 docking station features 6 downstream USB ports in total to connect USB peripherals and an SD (4.0) card reader for media storage.
  • 2x USB-C 3.2 Gen 2 - 10 Gbps (BC 1.2 Fast-Charge + Aways-On)
  • 2x USB-A 3.2 Gen 1 - 5 Gbps
  • 2x USB-A 2.0 - 480 Mbps
  • SD 4.0 Card Reader
Also included, is a gigabit Ethernet port with PXE Boot, as well as 4-position TRRS stereo audio for a headset and mic.
Additional Security Features
This USB-C docking station comes with plenty of security features two K-slots for a Kensington style laptop lock.
Connected Device Transparency with the StarTech.com MAC Address Changer Utility
The DK31C2DHSPDUE includes a free Windows application that enables you to better manage your enterprise network security. When you connect to your network through the ethernet port of the dock, the computer's MAC address is typically not broadcast to the network, as your network only sees the MAC address of the docking station. However, the StarTech.com MAC Address Changer or Cloning software enables the USB-C dock to use MAC address spoofing of the connected Windows laptop rather than the MAC address of the dock itself. This ensures your network administrators have full visibility of each device on the network and can monitor and limit activity accordingly. To request access to our MAC Address Changer utility, please contact our Technical Support Department by phone, live chat, or e-mail.
  • HDMI & DisplayPort for Multiple Monitor Outputs
  • Power & Charge with 100W Power Delivery
    Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 100 watt power delivery, to keep high performance laptops sufficiently charged during heavy productivity usage. Charge smartphones and other devices with USB-C downstream charging ports featuring BC 1.2 charging specification. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected.
  • Integrated 6-Port USB Hub & SD Card Reader
    This USB-C Gen 2 docking station features 6 downstream USB ports in total to connect USB peripherals and an SD (4.0) card reader for media storage. • 2x USB-C 3.2 Gen 2 - 10 Gbps (BC 1.2 Fast-Charge + Aways-On) • 2x USB-A 3.2 Gen 1 - 5 Gbps • 2x USB-A 2.0 - 480 Mbps • SD 4.0 Card Reader Also included, is a gigabit Ethernet port with PXE Boot, as well as 4-position TRRS stereo audio for a headset and mic.
  • Additional Security Features
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C Dock - Triple 4K Monitor USB Type-C Docking Station - 100W Power Delivery - DP 1.4 Alt Mode & DSC, 2x DisplayPort 1.4/HDMI 2.0 - 6xUSB (2x 10Gbps) - Windows/Chrome - docking station - USB-C - HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, 2 x DP
21 cm x 9 cm x 3 cm
300 g
Grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 100 Watt Power Provided
3-year warranty
Docking station
21 cm
9 cm
3 cm
300 g
Enclosure Colour
Grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz (DisplayPort 1.4 only)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
1 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x display / video - 20 pin DisplayPort , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 2 x USB-C 3.1 Gen 2 with Battery Charging 1.2 , 2 x SuperSpeed USB 3.0 , 2 x USB 2.0
1 x USB-C cable - detachable - 1 m , 2 x power cable
2 security lock slots (cable lock sold separately), Preboot Execution Environment (PXE) support, up to 3 monitors support, DisplayPort Alt Mode, 100W power delivery, HDR support
Security Slot Type
Kensington security slot
FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.4, DSC
Power adapter
AC 120/230 V
Power Provided
100 Watt
Apple iOS, Windows 8.1 / 10, Google Chrome OS 69.x, Apple macOS 10.12 - 11, Android 9.x
Limited warranty - 3 years
Shipping Width
27 cm
Shipping Depth
15 cm
Shipping Height
9.4 cm
Shipping Weight
1.4 kg
50 °C
Device Type: Laptop
Colour: Grey
