StarTech.com USB-C Dock, 2x DP, 100W PD
Quicklinx: JG67WS00 Mfr#: 201UE-USBC-DOCK
More than 50 In Stock
£87.84 ex VAT
£105.40 inc VAT
Transform a USB-C laptop into a dual-monitor workstation with DisplayPort video and USB-A and USB-C ports
Connect up to two 4K 60 Hz DisplayPort displays through a single USB-C port, while also providing USB-C, USB-A, and Gigabit Ethernet connectivity.
Uncompressed Video Over USB-C
Connect up to two 4K 60Hz DisplayPort displays through a single USB Type-C port with uncompressed video powered by your laptop's native GPU; Drive demanding workflows with high-performance visuals and no software compression
Driverless Deployment
Features plug-and-play functionality on Windows with no drivers or software required*. It is engineered for scalable, zero-touch rollouts across shared workspaces, corporate environments, and BYOD deployments.
Flexible, High-Speed I/O
This dock is equipped with 4× USB-A 5 Gbps ports and 2× USB-C 10 Gbps ports (including one with 15 W PD), providing support for both legacy peripherals and modern high-throughput devices without compromising performance. A Gigabit Ethernet port ensures a reliable wired network connection.
Mounting and Security
This multi-monitor dock includes built-in lock slots for enhanced physical security and supports Surface or VESA mounting to keep the dock secure and out of the way. Mounting accessories are sold separately (SSPMSUDWM, DOCK-NUC-VESA-MOUNT, SSPMSVESA).
*Note: Not compatible with macOS or ChromeOS
JG67 StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.29
JG67 StarTech.com USB-C Dock, 2x HDMI, 100W PD In Stock £87.84
JG67 StarTech.com 3x Monitor USB-C Dock, 100W PD In Stock £105.11
