StarTech.com USB-C Charging Cable, 240W PD White 4m
Quicklinx: HVMWWS00 Mfr#: USB2EPR4MW
Hurry, only 1 left in stock!
£14.64 ex VAT
£17.56 inc VAT
Discover the StarTech.com 4m USB C Charging Cable, a USB-IF Certified USB-C Cable designed to meet all your charging and data transfer needs. With a robust 10,000 insertions lifespan, this cable is built to last, ensuring a reliable connection time after time. It supports a high-speed data rate of 480 Mbps, making file transfers swift and efficient. The cable is engineered with advanced Power Delivery 3.1 support, allowing for up to 240 W of power delivery, perfect for devices requiring high power input. Additionally, it features EMI protection and is constructed with high-quality copper conductors, ensuring minimal interference and maximum performance. The eco-friendly design, being halogen-free, reflects a commitment to environmental sustainability. Whether you're charging your devices or syncing data, this cable is designed to provide a reliable, high-performance connection.
  • Enhanced durability
    Designed for longevity, this USB-C cable boasts a remarkable 10,000 insertions lifespan, ensuring reliable connectivity and performance for years to come.
  • High-speed data transfer
    Experience swift data transfer with a 480 Mbps data rate. This feature allows for quick syncing and file sharing between devices, enhancing efficiency.
  • Advanced power delivery
    Equipped with Power Delivery 3.1 support and an extended power range (EPR), this cable supports up to 240 W, enabling fast charging for devices that require higher power.
  • Superior construction
    Crafted with copper conductors and shielded with aluminum mylar foil with braid, this cable ensures reduced EMI interference and improved signal integrity.
  • Eco-friendly design
    Committed to environmental sustainability, the cable is halogen-free, reducing toxic emissions and promoting a greener planet.
StarTech.com 4m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
USB-C cable
Shielded
Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
4 m
Outside Diameter
4 mm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
140 g
