Experience a blend of performance and durability with the StarTech.com 3m USB C Charging Cable. Certified by USB-IF and designed to support up to 240 W with Power Delivery 3.1, this cable is your solution for fast charging and efficient data transfer. With a remarkable 10,000 insertions lifespan, it promises long-lasting reliability for all your charging needs. The cable features EMI protection and is constructed with high-quality copper conductors, ensuring minimal interference and maximum conductivity. Its eco-friendly, halogen-free design not only contributes to a greener planet but also offers a durable and flexible solution for everyday use. Whether you're syncing data or charging your devices, this USB-C cable is engineered to facilitate a seamless and powerful connection.
High durability
Designed for longevity, this USB-C cable has a 10,000 insertions lifespan, ensuring reliable connectivity and performance for years to come. -
Fast charging and data transfer
Equipped with an e-marker chip and supporting Power Delivery 3.1, this cable offers fast charging support and a 480 Mbps data rate, making it suitable for quick syncing and charging. -
Robust construction
Featuring copper conductors and a thermoplastic elastomer jacket, this cable is built for durability and efficient performance. Its EMI protection and aluminum mylar foil with braid shielding minimize interference, ensuring a stable connection. -
Eco-friendly design
This halogen-free cable is designed with environmental responsibility in mind, reducing harmful substances in its construction. -
Enhanced power delivery
With USB Power Delivery (240 W) and extended power range (EPR) support, this cable is capable of powering a wide range of devices, from smartphones to more demanding laptops, with ease.
- StarTech.com 3m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
- USB-C cable
- Technology
- Shielded
- Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
- Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 3 m
- Outside Diameter
- 4 mm
- White
- Connector
- USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 102 g
