StarTech.com USB-C Charging Cable, 240W PD White 3m
Quicklinx: HVMTWS00 Mfr#: USB2EPR3MW
Hurry, only 3 left in stock!
£13.14 ex VAT
£15.76 inc VAT
Experience a blend of performance and durability with the StarTech.com 3m USB C Charging Cable. Certified by USB-IF and designed to support up to 240 W with Power Delivery 3.1, this cable is your solution for fast charging and efficient data transfer. With a remarkable 10,000 insertions lifespan, it promises long-lasting reliability for all your charging needs. The cable features EMI protection and is constructed with high-quality copper conductors, ensuring minimal interference and maximum conductivity. Its eco-friendly, halogen-free design not only contributes to a greener planet but also offers a durable and flexible solution for everyday use. Whether you're syncing data or charging your devices, this USB-C cable is engineered to facilitate a seamless and powerful connection.
  • High durability
    Designed for longevity, this USB-C cable has a 10,000 insertions lifespan, ensuring reliable connectivity and performance for years to come.
  • Fast charging and data transfer
    Equipped with an e-marker chip and supporting Power Delivery 3.1, this cable offers fast charging support and a 480 Mbps data rate, making it suitable for quick syncing and charging.
  • Robust construction
    Featuring copper conductors and a thermoplastic elastomer jacket, this cable is built for durability and efficient performance. Its EMI protection and aluminum mylar foil with braid shielding minimize interference, ensuring a stable connection.
  • Eco-friendly design
    This halogen-free cable is designed with environmental responsibility in mind, reducing harmful substances in its construction.
  • Enhanced power delivery
    With USB Power Delivery (240 W) and extended power range (EPR) support, this cable is capable of powering a wide range of devices, from smartphones to more demanding laptops, with ease.
StarTech.com 3m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Shielded
Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
3 m
Outside Diameter
4 mm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
102 g
