The StarTech.com 2m USB C Charging Cable is a USB-IF Certified cable designed to meet the needs of high-demand devices. With support for USB Power Delivery (240 W) and Power Delivery 3.1, it offers fast charging capabilities for devices requiring substantial power. The cable is engineered for durability, featuring a 10,000 insertions lifespan and constructed with high-quality copper conductors and a thermoplastic elastomer jacket. It supports a 480 Mbps data rate, allowing for quick syncing and file transfers. Additionally, the cable is equipped with EMI protection and an e-marker chip, ensuring a safe and interference-free connection. Its eco-friendly, halogen-free design makes it an ideal choice for environmentally conscious users. Whether for professional use or personal convenience, this USB-C cable provides a reliable, efficient, and sustainable solution for charging and data transfer needs.
Enhanced durability
Designed for longevity, this USB-C cable has a 10,000 insertions lifespan, ensuring reliable connectivity and performance for years to come. Its robust construction, featuring copper conductors and a thermoplastic elastomer jacket, offers both flexibility and strength. -
High-speed charging and data transfer
Experience efficient charging with Power Delivery 3.1 support and a 240 W power capability, alongside a 480 Mbps data rate for rapid file transfers. This cable supports fast charging and sync, making it ideal for busy professionals and tech enthusiasts alike. -
Superior protection
Equipped with EMI protection and an e-marker chip, this cable ensures a safe and interference-free connection. The aluminum mylar foil with braid shielding further enhances its durability and reduces the risk of data loss. -
Eco-friendly design
Committed to environmental sustainability, this USB-C cable is halogen-free, reducing its ecological footprint. Its passive and bus-powered design also contributes to energy efficiency, making it a conscientious choice for eco-aware users.
- StarTech.com 2m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Technology
- Shielded
- Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 2 m
- Outside Diameter
- 4 mm
- White
- Connector
- USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 75 g
