StarTech.com USB-C Charging Cable, 240W PD White 2m
Quicklinx: HVMPWS00 Mfr#: USB2EPR2MW
40 In Stock
£10.84 ex VAT
£13.00 inc VAT
The StarTech.com 2m USB C Charging Cable is a USB-IF Certified cable designed to meet the needs of high-demand devices. With support for USB Power Delivery (240 W) and Power Delivery 3.1, it offers fast charging capabilities for devices requiring substantial power. The cable is engineered for durability, featuring a 10,000 insertions lifespan and constructed with high-quality copper conductors and a thermoplastic elastomer jacket. It supports a 480 Mbps data rate, allowing for quick syncing and file transfers. Additionally, the cable is equipped with EMI protection and an e-marker chip, ensuring a safe and interference-free connection. Its eco-friendly, halogen-free design makes it an ideal choice for environmentally conscious users. Whether for professional use or personal convenience, this USB-C cable provides a reliable, efficient, and sustainable solution for charging and data transfer needs.
  • Enhanced durability
    Designed for longevity, this USB-C cable has a 10,000 insertions lifespan, ensuring reliable connectivity and performance for years to come. Its robust construction, featuring copper conductors and a thermoplastic elastomer jacket, offers both flexibility and strength.
  • High-speed charging and data transfer
    Experience efficient charging with Power Delivery 3.1 support and a 240 W power capability, alongside a 480 Mbps data rate for rapid file transfers. This cable supports fast charging and sync, making it ideal for busy professionals and tech enthusiasts alike.
  • Superior protection
    Equipped with EMI protection and an e-marker chip, this cable ensures a safe and interference-free connection. The aluminum mylar foil with braid shielding further enhances its durability and reduces the risk of data loss.
  • Eco-friendly design
    Committed to environmental sustainability, this USB-C cable is halogen-free, reducing its ecological footprint. Its passive and bus-powered design also contributes to energy efficiency, making it a conscientious choice for eco-aware users.
StarTech.com 2m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
4 mm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1 cm
Shipping Weight
75 g
