StarTech.com USB-C Charging Cable, 240W PD White 1m
Quicklinx: HVMNWS00 Mfr#: USB2EPR1MW
20 In Stock
£10.10 ex VAT
£12.12 inc VAT
Experience reliable and efficient charging with the StarTech.com 1m USB C Charging Cable. Certified by USB-IF, this 240 W cable is designed to meet all your charging and data transfer needs. With a lifespan of 10,000 insertions and a data rate of 480 Mbps, it offers both durability and speed. The cable features EMI protection, copper conductors, and an e-marker chip, ensuring a safe and effective connection every time. It supports fast charging and sync for your convenience, alongside Power Delivery 3.1 and an extended power range (EPR) for high-powered devices. The environmentally conscious design, being halogen-free and constructed from thermoplastic elastomer, makes it a responsible choice. Whether you're at home, in the office, or on the go, this USB-C cable is the perfect solution for all your charging needs.
  • Enhanced Durability
    Designed to withstand up to 10,000 insertions, this USB-C cable is built for longevity, ensuring a lasting connection for all your devices.
  • High-Speed Performance
    With a 480 Mbps data rate, this cable supports fast data transfer, making it ideal for syncing and charging your devices efficiently.
  • Advanced Charging Technology
    Featuring Power Delivery 3.1 support and an extended power range (EPR), this cable can deliver up to 240 W, powering even the most demanding devices quickly.
  • Superior Protection
    EMI protection and a robust shielding material provide a secure, interference-free connection, while the e-marker chip ensures optimal performance.
  • Eco-Friendly Design
    Crafted from halogen-free materials, this passive cable is an environmentally conscious choice that doesn't compromise on quality or performance.
StarTech.com 1m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Shielded
Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
1 m
Outside Diameter
4 mm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22.5 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
Shipping Weight
25 g
