Experience reliable and efficient charging with the StarTech.com 1m USB C Charging Cable. Certified by USB-IF, this 240 W cable is designed to meet all your charging and data transfer needs. With a lifespan of 10,000 insertions and a data rate of 480 Mbps, it offers both durability and speed. The cable features EMI protection, copper conductors, and an e-marker chip, ensuring a safe and effective connection every time. It supports fast charging and sync for your convenience, alongside Power Delivery 3.1 and an extended power range (EPR) for high-powered devices. The environmentally conscious design, being halogen-free and constructed from thermoplastic elastomer, makes it a responsible choice. Whether you're at home, in the office, or on the go, this USB-C cable is the perfect solution for all your charging needs.
Enhanced Durability
Designed to withstand up to 10,000 insertions, this USB-C cable is built for longevity, ensuring a lasting connection for all your devices. -
High-Speed Performance
With a 480 Mbps data rate, this cable supports fast data transfer, making it ideal for syncing and charging your devices efficiently. -
Advanced Charging Technology
Featuring Power Delivery 3.1 support and an extended power range (EPR), this cable can deliver up to 240 W, powering even the most demanding devices quickly. -
Superior Protection
EMI protection and a robust shielding material provide a secure, interference-free connection, while the e-marker chip ensures optimal performance. -
Eco-Friendly Design
Crafted from halogen-free materials, this passive cable is an environmentally conscious choice that doesn't compromise on quality or performance.
- StarTech.com 1m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- Halogen-free, passive cable, extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, e-marker chip, copper conductors, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 4 mm
- White
- Connector
- USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
- Shipping Width
- 22.5 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 25 g
