StarTech.com USB-C Charging Cable, 240W PD Black 4m
Quicklinx: HVMVWS00 Mfr#: USB2EPR4M
Length: 4m
10 In Stock
£15.13 ex VAT
£18.15 inc VAT
Experience the perfect blend of durability and performance with the StarTech.com 4m USB C Charging Cable. Certified by USB-IF and designed to support up to 240 W of power delivery, this cable is an essential tool for powering high-end devices. It features a robust design capable of withstanding 10,000 insertions, ensuring a long-lasting and reliable connection. With a data transfer rate of 480 Mbps, it's ideal for fast syncing and charging of your devices. The cable's braided design and EMI protection minimize interference, while its compliance with FCC, RoHS, and WEEE standards reflects its quality and environmental friendliness. Whether you're at home, in the office, or on-the-go, this USB-C cable is the perfect solution for all your charging needs.
  • Robust durability
    Designed to withstand up to 10,000 insertions, this USB-C cable is built for longevity, ensuring a lasting connection for all your devices.
  • High-speed performance
    With a 480 Mbps data rate, this cable supports fast data transfer, making it ideal for syncing and charging your devices efficiently.
  • Enhanced power delivery
    Capable of delivering up to 240 W of power, this cable meets the needs of devices requiring high power input, supported by Power Delivery 3.1 and extended power range (EPR) technology.
  • Superior construction
    Featuring a braided design and EMI protection, this cable is not only durable but also minimizes interference, ensuring a reliable connection.
  • Eco-friendly choice
    Constructed without the use of halogens, this passive, shielded USB-C cable is an environmentally friendly option for your tech needs.
StarTech.com 4m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
USB-C cable
Shielded
Halogen-free, passive cable, extended power range (EPR), Power Delivery 3.1 support, sync and charge, braided, EMI protection, e-marker chip, 480 Mbps data rate, fast charging support, up to 240 Watts of power delivery, 10000 insertions lifespan
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
4 m
Outside Diameter
4 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
140 g
Length: 4m
