StarTech.com USB-C Charging Cable, 240W PD 3m
Quicklinx: J4L3WS00 Mfr#: S2CEPR3M-USB-CABLE
Length: 3m
Hurry, only 1 left in stock!
£15.60 ex VAT
£18.72 inc VAT
Connect a charger or hub to a USB PD 3.1-enabled device with this USB-C cable, delivering up to 240W EPR Power Delivery and 5A output for fast charging. Clear connector markings ensure quick identification, eliminating guesswork and ensuring full 240W charging support. Always choose the correct Type-C cable for optimal performance and compatibility. It supports USB 2.0 (480Mbps) throughput for general file transfer. The USB-C EPR Charging Cable features a silicone inner jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are rated to operate beyond 20,000 insertion cycles, enhancing its durability and longevity. Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 6-foot USB Type-C cable is the ideal length for large desks and mobile workstations where extra reach is desired. With up to 5A of output, the USB-C Charger Cord supports up to 240W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
  • Durable construction
    The nylon braided design provides a strong exterior and enhances the overall durability of the cable, ensuring it can withstand daily use without fraying or damage.
  • Fast data transfer
    With a data rate of 480 Mbps, this cable allows for quick and efficient file transfers, making it ideal for users who frequently move large amounts of data.
  • High power delivery
    The USB Power Delivery capability allows the cable to deliver power up to 240 W, suitable for charging laptops, smartphones, and other devices requiring higher wattage.
  • Long lifespan
    Engineered to last, this cable offers over 20,000 insertions lifespan, ensuring it remains functional and reliable even with frequent use.
  • Flexible design
    The silicone jacket provides comfort during use and protects the inner wiring against bends and twists.
StarTech.com 3m USB-C Charging Cable, 240W, Silicone Jacket w/Braid - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
USB Power Delivery (240W), extended power range (EPR), 20000+ insertions lifespan, rugged, nylon braided, 480 Mbps data rate
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Jacket Material
Silicone
American Wire Gauge (AWG)
30
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
3 m
Outside Diameter
4.2 mm
151 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, Power Delivery (EPR), USB Power Delivery 3.1, RoHS, USB-IF
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
2 cm
Shipping Weight
157 g
J4L3 StarTech.com USB-C Charging Cable, 240W PD 1m In Stock £11.16
J4L3 StarTech.com USB-C Charging Cable, 240W PD 2m In Stock £11.69
Length: 3m
