Connect a charger or hub to a USB PD 3.1-enabled device with this USB-C cable, delivering up to 240W EPR Power Delivery and 5A output for fast charging. Clear connector markings ensure quick identification, eliminating guesswork and ensuring full 240W charging support. Always choose the correct Type-C cable for optimal performance and compatibility. It supports USB 2.0 (480Mbps) throughput for general file transfer. The USB-C EPR Charging Cable features a silicone inner jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are rated to operate beyond 20,000 insertion cycles, enhancing its durability and longevity. Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 6-foot USB Type-C cable is the ideal length for desk and mobile workstations or to reduce clutter when syncing with a USB-C laptop. With up to 5A of output, the USB-C Charger Cord supports up to 240W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
                Robust constructionThe nylon braided exterior and silicone jacket enhance the durability of the cable, making it ideal for everyday use and travel.
                High data rateWith a data rate of 480 Mbps, this USB-C cable allows for quick and efficient data transfers, perfect for transferring large files between devices.
                Extended power rangeThis cable supports USB Power Delivery up to 240 W, providing an effective means of charging laptops and other high-power devices quickly and safely.
                Long lifespanDesigned to withstand over 20,000 insertions, this cable is built for longevity, ensuring consistent performance throughout its use.
                Versatile compatibilityCompatible with a wide range of devices including smartphones, tablets, and laptops, this cable serves various charging and data transfer needs seamlessly.
- StarTech.com 2m USB-C Charging Cable, 240W, Silicone Jacket w/Braid - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- USB Power Delivery (240W), extended power range (EPR), 20000+ insertions lifespan, rugged, nylon braided, 480 Mbps data rate
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Jacket Material
- Silicone
- American Wire Gauge (AWG)
- 30
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 2 m
- Outside Diameter
- 4.2 mm
- Black
- 81 g
- Connector
- USB / USB 2.0, Power Delivery (EPR), USB Power Delivery 3.1, RoHS, USB-IF
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 87 g
|  | StarTech.com USB-C Charging Cable, 240W PD 1m | In Stock | £10.90 |
|  | StarTech.com USB-C Charging Cable, 240W PD 3m | In Stock | £15.56 |
