StarTech.com USB-C Charging Cable, 240W PD 1m
Quicklinx: J4L1WS00 Mfr#: S2CEPR1M-USB-CABLE
Length: 1m
30 In Stock
£11.16 ex VAT
£13.39 inc VAT
Connect a charger or hub to a USB PD 3.1-enabled device with this USB-C cable, delivering up to 240W EPR Power Delivery and 5A output for fast charging. Clear connector markings ensure quick identification, eliminating guesswork and ensuring full 240W charging support. Always choose the correct Type-C cable for optimal performance and compatibility. It supports USB 2.0 (480Mbps) throughput for general file transfer. The USB-C EPR Charging Cable features a silicone inner jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are rated to operate beyond 20,000 insertion cycles, enhancing its durability and longevity. Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 1-meterUSB Type-C cable is the ideal length for desk and mobile workstations or when syncing with a USB-C laptop. With up to 5A of output, the USB-C Charger Cord supports up to 240W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
  • Durable construction
    This USB-C cable features a nylon braided design, providing resilience against daily wear and tear while maintaining flexibility.
  • High-speed data transfer
    With a data rate of 480 Mbps, this cable enables efficient and seamless data exchange between connected devices.
  • Extended power delivery
    Equipped with USB Power Delivery, this cable supports up to 240 W of power, making it suitable for charging laptops and other high-demand devices.
  • Long lifespan
    Designed for a lifespan of over 20,000 insertions, this cable provides reliability for frequent use.
  • Versatile compatibility
    Compatible with a wide range of USB-C devices, this cable is perfect for various applications, from charging smartphones to connecting peripherals.
StarTech.com 1m USB-C Charging Cable, 240W, Silicone Jacket w/Braid - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
USB Power Delivery (240W), extended power range (EPR), 20000+ insertions lifespan, rugged, nylon braided, 480 Mbps data rate
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Jacket Material
Silicone
American Wire Gauge (AWG)
30
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
1 m
Outside Diameter
4.2 mm
41 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, Power Delivery (EPR), USB Power Delivery 3.1, RoHS, USB-IF
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.6 cm
Shipping Weight
47 g
J4L1 StarTech.com USB-C Charging Cable, 240W PD 2m In Stock £11.69
J4L1 StarTech.com USB-C Charging Cable, 240W PD 3m In Stock £15.60
Length: 1m
