Discover the efficiency and durability of the StarTech.com 2 m USB C Charging Cable, designed to meet your charging and data transfer needs. This USB-IF Certified cable supports fast charging with its 240 W Power Delivery 3.1, ensuring your devices are quickly and safely charged. With a data transfer rate of 480 Mbps, it facilitates swift sync and charge functionality, making it an ideal companion for your devices. The cable is constructed with a durable thermoplastic elastomer (TPE) jacket and features aluminum mylar foil with braid shielding, ensuring a long-lasting and reliable connection. Rated for 10,000 insertions, it promises enduring performance. Additionally, it offers EMI protection to minimize interference and ensure a stable connection, while its halogen-free design marks it as an environmentally friendly choice. Certified by USB-IF, FCC, RoHS, and WEEE, this cable stands out as a high-quality, sustainable option for your connectivity needs.
Fast charging and data transfer
Equipped with Power Delivery 3.1 support and a 240 W USB Power Delivery, this 2 m USB C Charging Cable ensures your devices charge quickly and safely. With a 480 Mbps data rate, it also offers efficient sync and charge capabilities for your convenience. -
Durable design
Designed for longevity, this cable features a robust thermoplastic elastomer (TPE) jacket, aluminum mylar foil with braid shielding, and is rated for 10,000 insertions lifespan, ensuring a durable and reliable connection. -
EMI protection
With built-in EMI protection, this USB-C cable safeguards against interference, ensuring a stable and secure data transmission. -
Eco-friendly choice
Halogen-free construction makes this cable an environmentally friendly option, reducing toxic emissions and promoting a greener planet.
- StarTech.com 2m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Technology
- Shielded
- Extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, halogen free, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 2 m
- Outside Diameter
- 4 mm
- Black
- Connector
- USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
- Shipping Width
- 22.5 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 75 g
StarTech.com USB-C Charging Cable, 240W PD - 1m | In Stock | £10.10 |
StarTech.com USB-C Charging Cable, 240W PD Black 3m | In Stock | £14.04 |
StarTech.com USB-C Charging Cable, 240W PD Black 4m | In Stock | £15.40 |
