StarTech.com USB-C Charging Cable, 240W PD - 2m
Quicklinx: HQ31WS00 Mfr#: USB2EPR2M
Length: 2m
More than 50 In Stock
£10.56 ex VAT
£12.67 inc VAT
Discover the efficiency and durability of the StarTech.com 2 m USB C Charging Cable, designed to meet your charging and data transfer needs. This USB-IF Certified cable supports fast charging with its 240 W Power Delivery 3.1, ensuring your devices are quickly and safely charged. With a data transfer rate of 480 Mbps, it facilitates swift sync and charge functionality, making it an ideal companion for your devices. The cable is constructed with a durable thermoplastic elastomer (TPE) jacket and features aluminum mylar foil with braid shielding, ensuring a long-lasting and reliable connection. Rated for 10,000 insertions, it promises enduring performance. Additionally, it offers EMI protection to minimize interference and ensure a stable connection, while its halogen-free design marks it as an environmentally friendly choice. Certified by USB-IF, FCC, RoHS, and WEEE, this cable stands out as a high-quality, sustainable option for your connectivity needs.
  • Fast charging and data transfer
    Equipped with Power Delivery 3.1 support and a 240 W USB Power Delivery, this 2 m USB C Charging Cable ensures your devices charge quickly and safely. With a 480 Mbps data rate, it also offers efficient sync and charge capabilities for your convenience.
  • Durable design
    Designed for longevity, this cable features a robust thermoplastic elastomer (TPE) jacket, aluminum mylar foil with braid shielding, and is rated for 10,000 insertions lifespan, ensuring a durable and reliable connection.
  • EMI protection
    With built-in EMI protection, this USB-C cable safeguards against interference, ensuring a stable and secure data transmission.
  • Eco-friendly choice
    Halogen-free construction makes this cable an environmentally friendly option, reducing toxic emissions and promoting a greener planet.
StarTech.com 2m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
Extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, halogen free, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
4 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
Shipping Width
22.5 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
Shipping Weight
75 g
HQ31 StarTech.com USB-C Charging Cable, 240W PD - 1m In Stock £9.36
HQ31 StarTech.com USB-C Charging Cable, 240W PD Black 3m In Stock £13.69
HQ31 StarTech.com USB-C Charging Cable, 240W PD Black 4m In Stock £15.37
Length: 2m
