QUALITY CONSTRUCTION: Nickel-plated connectors rated beyond 10,000 insertion cycles; 30AWG wire tested to withstand 120° bends; Braided Aluminum shield for enhanced EMI protection; Durable TPE outer jacket is halogen-free and RoHS compliant
PERFORMANCE: 240W/5A PD 3.1 EPR, 48V; Backward Compatible w/140W/100W/60W; USB 2.0 Type-C (480Mbps); 1-meter (3.3-foot) cable; Color: Black; O.D.: 0.16in (4.0mm); TPE Jacket w/Braided Aluminum Shield; NOTE: USB-C video (DP Alt Mode) is not supported
USB-C EPR CHARGING CABLE: USB Type-C cable supports Power Delivery 3.1 Extended Power Range (EPR); Up to 240W output for charging high-performance USB-C laptops and devices; Connects to a USB-C wall charger, power bank, or external USB-C hub
Fast charging and data transfer
Experience efficient charging and rapid data transfer with this USB-C cable, supporting up to 240 W power delivery and a 480 Mbps data rate. Its design ensures you can charge your devices and transfer data quickly and securely. -
Durable design
Built for longevity, this cable boasts a 10,000 insertions lifespan, featuring a robust thermoplastic elastomer (TPE) jacket and nickel-plated connectors. It's engineered to withstand frequent use while maintaining optimal performance. -
Enhanced power delivery
Equipped with Power Delivery 3.1 support and an extended power range (EPR), this cable is designed to handle high-power charging up to 240 W, making it ideal for devices requiring substantial power. -
EMI protection
With EMI protection and a shielded technology, this cable ensures a reliable connection free from electromagnetic interference, providing a seamless charging and data transfer experience. -
Eco-friendly choice
Prioritizing environmental sustainability, this cable is halogen-free, reducing harmful emissions and promoting a greener, safer choice for tech accessories.
- StarTech.com 1m USB C Charging Cable, USB-IF Certified USB-C Cable, 240W - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- Extended power range (EPR), USB Power Delivery (240W), Power Delivery 3.1 support, sync and charge, EMI protection, halogen free, 480 Mbps data rate, fast charging support, bus powered, 10000 insertions lifespan
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 4 mm
- Black
- Connector
- USB / USB 2.0, FCC, RoHS, USB-IF, WEEE
- Shipping Width
- 22.5 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 25 g
StarTech.com USB-C Charging Cable, 240W PD - 2m | In Stock | £11.71 |
