StarTech.com USB-C Cable with Lightning
Quicklinx: JG75WS00 Mfr#: 1M-U2-LNTC-CABLE
More than 50 In Stock
£11.83 ex VAT
£14.19 inc VAT
Charge an Apple Lightning device or a USB-C device from any USB-C power source
Equip your workspace with a versatile 2-in-1 USB-C to C cable that provides charging for both USB-C and Apple Lightning devices.
2-in-1 USB Charging Cable
Keep this USB-C cable with an integrated Lightning adapter on hand and minimize the need for carrying multiple charging cables. The dual-format design makes it easy to switch between USB-C and Lightning portable devices. It also supports USB 480Mbps speeds for general file transfer and device syncing. The cable can charge one device at a time.
Charge your devices from any USB-C wall charger, car charger, or power bank. The attached adapter swaps quickly to support compatibility across USB-C and Apple Lightning devices.
Rugged Design
The USB-C cable's rugged braided-nylon outer jacket provides reliable protection against wear from frequent daily use. A flexible TPE inner jacket absorbs stress from repeated bends, delivering long-term durability without added bulk.
Easy to Use
To charge or sync a Lightning mobile device, attach the USB-C female to Lightning adapter to the USB-C connector and plug into your device. To charge or sync a USB-C device, simply use the primary USB-C connectors on both ends of the cable.
1M-U2-LNTC-CABLE is Apple MFi certified for guaranteed compatibility with Apple Lightning-enabled devices.
