Charge your USB 2.0 USB-C devices, such as your MacBook or Chromebook, from a USB-C AC wall charger. This USB-C to USB-C cable lets you charge and sync your USB Type-C devices. It's also compatible with Thunderbolt 3 ports.
Connect your newer USB-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, to your computer. The cable delivers up to a 3 amp charge, and supports data transfer speeds of up to 480Mbps.
With up to 3A of power output, this USB Type-C cable can also be used to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect your laptop to your USB-C wall charger.
Replace the cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
This USB-C cable has been certified with USB-IF (USB Implementers Forum) in order to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards set by USB compliance. This ensures a high-quality, reliable cable for all your USB-C devices.
- StarTech.com 1m / 3.3ft USB C to USB C Cable - USB 2.0 Type C Cable - M/M - USB-IF Certified - USB C Charging Cable - USB 2.0 (USB2CC1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Double shielded
- 480 Mbps data rate
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: DKT30CHD, HB30C1A1CPD, HB30C3A1CFBW, PEXUS313AC2V
- USB-C cable
- Technology
- Double shielded
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- 25 g
- Connector
- USB / USB 2.0, RoHS
- 2-year warranty
- Designed For
|  | StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £7.73 |
|  | StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
|  | StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.60 |
|  | StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.07 |
|  | StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.20 |
|  | StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £9.60 |
|  | StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.00 |
|  | StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.05 |
|  | StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £4.62 |
|  | StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
|  | StarTech.com 2m 6ft USB 2.0 USB-C Cable | In Stock | £11.23 |
|  | StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.41 |
|  | StarTech.com 0.5m USB 2.0 USB C Cable | In Stock | £8.74 |
|  | StarTech.com 1m Lightning USB C Micro-B Cbl | In Stock | £23.64 |
|  | StarTech.com 1m Right Angle USB C Cable | In Stock | £11.21 |
|  | StarTech.com 3m USB 2.0 Type C Cable | In Stock | £11.56 |
|  | StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £15.26 |
