USB Type-C Headphone and Charger Adapter Audio & Charge 60W PD. This USB C audio adapter with 60W power delivery features a USB Type-C audio port for your headset, audio out or data transfer, while allowing you to charge your laptop, tablet, or smartphone at the same time.
Listen & Charge Simultaneously
Make calls or listen to music with this USB C audio and charging adapter. The 2 in 1 headphone adapter with charge port allows you to use your USB-C headsets, speakers, or transfer data (USB 2.0 speeds) while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected.
Sleek and Portable Design
The USB C audio adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio and charge solution for your USB Type-C devices.
Wide Compatibility
This USB C headset adapter is universally compatible enabling you to use your wired headphones with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note.
CDP2CAPDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
Make calls or listen to music with this USB C audio and charging adapter. The 2 in 1 headphone adapter with charge port allows you to use your USB-C headsets, speakers, or transfer data (USB 2.0 speeds) while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected. -
The USB C audio adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio and charge solution for your USB Type-C devices. -
Wide Compatibility
This USB C headset adapter is universally compatible enabling you to use your wired headphones with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note. CDP2CAPDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
- StarTech.com USB C Audio & Charge Adapter, USB-C Audio Adapter with USB-C Audio Headphone/Headset Port and 60W USB Type-C Power Delivery Pass-through Charger, For USB-C Phone/Tablet/Laptop - USB-C Audio/Charging (CDP2CAPDM) - docking station - USB-C
- Product Type
- Docking station
- Docking Interface
- USB-C
- 2.25 cm x 4.99 cm x 0.9 cm
- 8 g
- Silver
- 3-year warranty
- Product Type
- Docking station
- 2.25 cm
- 4.99 cm
- 0.9 cm
- 8 g
- Enclosure Colour
- Silver
- USB-C with Power Delivery (60 W) - 24 pin USB-C , Audio - USB 2.0 - 24 pin USB-C
- 60W power delivery
- FCC, RoHS, WEEE
- OS Required
- Android, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Windows 10 / 11 or later, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Width
- 9 cm
- Shipping Depth
- 12.5 cm
- Shipping Weight
- 9 g
- 0 °C
- 45 °C
StarTech.com USB C Audio & Charge Adapter - 3.5mm Headphone Jack/ 60W USB | In Stock | £18.73 |
StarTech.com USB-C Headphone Splitter | In Stock | £19.25 |
StarTech.com USB-C Audio Adapter to 3.5mm | In Stock | £11.52 |
StarTech.com USB-C to RJ9 Adapter/Dongle | In Stock | £27.45 |
