USB Type-C to 3.5mm Headphone Adapter Audio & Charge 60W PD. This USB C audio adapter with 60W power delivery lets you convert the USB-C port of your device into a 3.5mm audio jack, while allowing you to charge your laptop, tablet or smartphone at the same time.
Listen & Charge Simultaneously
Make calls or listen to music with this USB audio and charging adapter. The 2 in 1 USB-C adapter with headphone jack and charging port allows you to continue to use your legacy headsets, speakers or microphones with your USB Type-C devices, while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected. The adapter also supports Quick Charge (QC 2.0) and BC 1.2 charging.
Sleek and Portable Design
The USB Type C to aux adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio solution for your USB-C devices that do not have a 3.5mm input.
Wide Compatibility
This USB C to headphone jack is universally compatible enabling you to use your existing wired headset with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note.
CDP235APDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
Make calls or listen to music with this USB audio and charging adapter. The 2 in 1 USB-C adapter with headphone jack and charging port allows you to continue to use your legacy headsets, speakers or microphones with your USB Type-C devices, while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected. The adapter also supports Quick Charge (QC 2.0) and BC 1.2 charging. -
The USB Type C to aux adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio solution for your USB-C devices that do not have a 3.5mm input. -
Wide Compatibility
This USB C to headphone jack is universally compatible enabling you to use your existing wired headset with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note. CDP235APDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
- StarTech.com USB C Audio & Charge Adapter, USB-C Audio Adapter w/ 3.5mm TRRS Headphone/Headset Jack and 60W USB Type-C Power Delivery Pass-through Charger, For USB-C Phone/Tablet/Laptop - USB-C to Audio & Charging (CDP235APDM) - docking station - USB-C
- Product Type
- Docking station
- Docking Interface
- USB-C
- 2.25 cm x 4.99 cm x 0.9 cm
- 8 g
- Silver
- 3-year warranty
- Product Type
- Docking station
- 2.25 cm
- 4.99 cm
- 0.9 cm
- 8 g
- Enclosure Colour
- Silver
- USB-C with Power Delivery (60 W) - 24 pin USB-C , Audio - mini-phone 3.5 mm
- 60W power delivery
- FCC, RoHS, WEEE
- OS Required
- Android, Apple iPadOS, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Windows 10 / 11 or later, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Width
- 9 cm
- Shipping Depth
- 12.5 cm
- Shipping Weight
- 9 g
- 0 °C
- 45 °C
StarTech.com USB-C Headphone Splitter | In Stock | £18.89 |
StarTech.com USB-C Audio Adapter to 3.5mm | In Stock | £11.86 |
