StarTech.com USB C Audio & Charge Adapter - 3.5mm Headphone Jack/ 60W USB
Quicklinx: GBSZWS00 Mfr#: CDP235APDM
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver
£17.80 ex VAT
£21.36 inc VAT
USB Type-C to 3.5mm Headphone Adapter Audio & Charge 60W PD. This USB C audio adapter with 60W power delivery lets you convert the USB-C port of your device into a 3.5mm audio jack, while allowing you to charge your laptop, tablet or smartphone at the same time.
Listen & Charge Simultaneously
Make calls or listen to music with this USB audio and charging adapter. The 2 in 1 USB-C adapter with headphone jack and charging port allows you to continue to use your legacy headsets, speakers or microphones with your USB Type-C devices, while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected. The adapter also supports Quick Charge (QC 2.0) and BC 1.2 charging.
Sleek and Portable Design
The USB Type C to aux adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio solution for your USB-C devices that do not have a 3.5mm input.
Wide Compatibility
This USB C to headphone jack is universally compatible enabling you to use your existing wired headset with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note.
CDP235APDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
  • Listen & Charge Simultaneously
  • Sleek and Portable Design
  • Wide Compatibility
    This USB C to headphone jack is universally compatible enabling you to use your existing wired headset with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note. CDP235APDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com USB C Audio & Charge Adapter, USB-C Audio Adapter w/ 3.5mm TRRS Headphone/Headset Jack and 60W USB Type-C Power Delivery Pass-through Charger, For USB-C Phone/Tablet/Laptop - USB-C to Audio & Charging (CDP235APDM) - docking station - USB-C
Docking station
Docking Interface
USB-C
2.25 cm x 4.99 cm x 0.9 cm
8 g
Silver
3-year warranty
Docking station
2.25 cm
4.99 cm
0.9 cm
8 g
Enclosure Colour
Silver
USB-C with Power Delivery (60 W) - 24 pin USB-C , Audio - mini-phone 3.5 mm
60W power delivery
FCC, RoHS, WEEE
Android, Apple iPadOS, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Windows 10 / 11 or later, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
9 cm
Shipping Depth
12.5 cm
Shipping Weight
9 g
45 °C
GBSZ StarTech.com USB-C Headphone Splitter In Stock £19.49
GBSZ StarTech.com USB-C Audio Adapter to 3.5mm In Stock £11.49
Device Type: Laptop
Colour: Silver
