Connect wired headphones or earphones to a USB Type-C-enabled device with this USB-C to 3.5mm audio adapter. The built-in 32-bit DAC supports stereo sound and microphone functionality via the TRRS jack for clear audio. It delivers excellent sound quality with audio ranges from 44.1 to 384kHz and 16, 24, and 32-bit sample rates, providing a 105dBA signal-to-noise ratio. The stereo ADC features a 94dB SNR for microphone input, with 48kHz and 16-bit sampling. Compatible with USB-C and Thunderbolt devices, including Windows, macOS, and Linux computers, as well as phones and tablets running iOS or Android, it supports wired headphones and headsets with in-line controls. The compact, sleek adapter measures 5 inches (127mm) and features a flexible and durable TPE jacket with a soft-touch finish. Perfect for use on the go or at a workstation for audio playback, recording, or calls.
Superior Sound Quality
Experience excellent sound quality supporting audio ranges from 44.1 to 384kHz and 16, 24, and 32-bit sample rates, delivering a 105dBA signal-to-noise ratio for crisp and detailed output. The stereo ADC features a 94dB SNR for microphone input, with 48kHz and 16-bit sampling, all powered by the Realtek ALC4030U chipset. -
Wide Compatibility
This versatile aux audio adapter is universally compatible with USB-C and Thunderbolt devices, including Windows, macOS, and Linux computers, as well as phones and tablets running iOS or Android. It supports wired headphones and headsets (including models with in-line controls), making it an ideal solution for using existing audio gear and eliminating the need for Bluetooth audio solutions. -
Sleek and Portable Design
The compact, sleek adapter measures just 5 inches (127mm) and features a flexible and durable TPE jacket with a soft-touch finish. Use this adapter cable on the go or at a workstation for audio playback, recording, or calls.
- StarTech.com USB-C Audio Adapter to 3.5mm TRRS Jack, Headphone Aux Dongle - USB-C to headphone jack adapter - 12.7 cm
- Cable
- Length
- 12.7 cm
- Black
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4-pole mini jack - female
- USB / USB 2.0
- DAC
- DAC Details
- 44.1 - 384 kHz - SNR: 105 dB
- 32-bit DAC, Realtek ALC4030U chipset
- 2-year warranty
- Cable Type
- Jacket Material
- Thermoplastic elastomer (TPE)
- USB / USB 2.0
- Length
- 12.7 cm
- Recommended Use
- Laptop, phone, tablet
- Black
Adapters & Converters
- Audio Output
- Stereo
- DAC
- Frequency Response
- 44.1 - 384 kHz
- Signal-To-Noise Ratio
- 105 dB
- OS Required
- Microsoft Windows 10 / 11, Apple macOS Sequoia 15.0, Apple macOS Sonoma 14.0, Apple macOS Ventura 13.0, Apple iPadOS, Apple iOS, Android
- Connector
- Mini-phone 3.5 mm 4-pole - female
- RoHS, WEEE, CTIA, OMTP
- 9 g
- Shipping Width
- 22 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 1.2 cm
- Shipping Weight
- 15 g
- Limited warranty - 2 years
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £4.72 |
StarTech.com 1m White Slim 3.5mm Stereo Audio Cable - Male to Male | In Stock | £3.37 |
StarTech.com USB-C to RJ9 Adapter/Dongle | In Stock | £27.45 |
