Ideal for mobile workers, this USB-C multiport adapter with HDMI and VGA gives you flexible video output. It's like four adapters in one, with HDMI or VGA connections, a Gigabit Ethernet port and a USB 3.0 port, all through one connection to your laptop's USB-C port. Plus, it features a hideaway cable for better cable management and easier travel.
With easy plug-and-play installation on most operating systems, the USB-C adapter doesn't require additional drivers or software. It's the perfect accessory for MacBook Pro, Dell XPS, Chromebook or other USB-C laptops.
The USB Type-C multiport adapter keeps you prepared for business travel. You can extend your laptop's display by connecting to a 4K HDMI (4096x2160 or 3840 x 2160p) or VGA (1920 x 1200p) monitor or projector, to make presentations or set up a workstation.
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock, for easy connections on the go. Plus, the USB Type-C adapter is bus powered, so there's no need to carry around a separate power adapter.
Connect a flash drive, mouse or other peripheral to your USB-C or Thunderbolt 3 laptop using the USB 3.0? Type-A port. The USB-C adapter adds wired network connectivity with the GbE port, making it ideal in areas without Wi-Fi.
Connect a UHD 4K HDMI or VGA Monitor
The USB Type-C multiport adapter keeps you prepared for business travel. You can extend your laptop's display by connecting to a 4K HDMI (4096x2160 or 3840 x 2160p) or VGA (1920 x 1200p) monitor or projector, to make presentations or set up a workstation. -
Convenient Cable Management
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock, for easy connections on the go. Plus, the USB Type-C adapter is bus powered, so there's no need to carry around a separate power adapter. -
Enhance Productivity
Connect a flash drive, mouse or other peripheral to your USB-C or Thunderbolt 3 laptop using the USB 3.0?Type-A port. The USB-C adapter adds wired network connectivity with the GbE port, making it ideal in areas without Wi-Fi. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB C Multiport Adapter with HDMI, VGA, Gigabit Ethernet & USB 3.0, USB C to 4K HDMI or 1080p VGA Display Mini Dock Hub, USB Type-C Travel Docking Station for USB-C Laptops - Portable USB-C Dock (DKT30CHVCM) - docking station - USB-C - VGA, HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI
- 6.5 cm x 10.5 cm x 1.6 cm
- 82 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 6.5 cm
- 10.5 cm
- 1.6 cm
- 82 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 4096 x 2160 - 24 Hz (HDMI only) , 3840 x 2160 - 30 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - integrated - 8.5 cm
- USB powered
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 200 g
StarTech.com USB-C Multifunction Adapter | In Stock | £47.42 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £12.06 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £22.67 |
StarTech.com USB-C Adapter with HDMI & VGA | In Stock | £29.93 |
StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock | In Stock | £60.11 |
