StarTech.com USB-C Adapter with HDMI & VGA
Quicklinx: F2K2WS00 Mfr#: DKT30CHVCM
£32.45 ex VAT
£38.94 inc VAT
Ideal for mobile workers, this USB-C multiport adapter with HDMI and VGA gives you flexible video output. It's like four adapters in one, with HDMI or VGA connections, a Gigabit Ethernet port and a USB 3.0 port, all through one connection to your laptop's USB-C port. Plus, it features a hideaway cable for better cable management and easier travel.
With easy plug-and-play installation on most operating systems, the USB-C adapter doesn't require additional drivers or software. It's the perfect accessory for MacBook Pro, Dell XPS, Chromebook or other USB-C laptops.
The USB Type-C multiport adapter keeps you prepared for business travel. You can extend your laptop's display by connecting to a 4K HDMI (4096x2160 or 3840 x 2160p) or VGA (1920 x 1200p) monitor or projector, to make presentations or set up a workstation.
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock, for easy connections on the go. Plus, the USB Type-C adapter is bus powered, so there's no need to carry around a separate power adapter.
Connect a flash drive, mouse or other peripheral to your USB-C or Thunderbolt 3 laptop using the USB 3.0? Type-A port. The USB-C adapter adds wired network connectivity with the GbE port, making it ideal in areas without Wi-Fi.
  • Connect a UHD 4K HDMI or VGA Monitor
  • Convenient Cable Management
  • Enhance Productivity
    Connect a flash drive, mouse or other peripheral to your USB-C or Thunderbolt 3 laptop using the USB 3.0?Type-A port. The USB-C adapter adds wired network connectivity with the GbE port, making it ideal in areas without Wi-Fi.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C Multiport Adapter with HDMI, VGA, Gigabit Ethernet & USB 3.0, USB C to 4K HDMI or 1080p VGA Display Mini Dock Hub, USB Type-C Travel Docking Station for USB-C Laptops - Portable USB-C Dock (DKT30CHVCM) - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
6.5 cm x 10.5 cm x 1.6 cm
82 g
Gigabit Ethernet
3-year warranty
Docking station
6.5 cm
10.5 cm
1.6 cm
82 g
Enclosure Colour
Video
Max Resolution Details
4096 x 2160 - 24 Hz (HDMI only) , 3840 x 2160 - 30 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45
1 x USB-C cable - integrated - 8.5 cm
USB powered
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
200 g
F2K2 StarTech.com USB-C Multifunction Adapter In Stock £45.56
F2K2 StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £44.93
F2K2 StarTech.com USB-C to VGA Adapter with PD In Stock £35.85
F2K2 StarTech.com USB-C Multiport Adapter - DVI In Stock £24.59
F2K2 StarTech.com USB-C Adapter with HDMI & VGA In Stock £32.45
F2K2 StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £58.64
