StarTech.com USB-C Adapter - HDMI and VGA
Quicklinx: DPJ9WS00 Mfr#: DKT30CHVSCPD
More than 50 In Stock
£44.66 ex VAT
£53.59 inc VAT
Add video output, three USB 3.0 ports, SD/micro SD card readers, and GbE port to your laptop through a single USB-C port. Turn your USB-C equipped laptop into a mobile workstation. This sleek, compact USB-C multiport adapter makes it easy to connect your MacBook Pro or Windows laptop to an HDMI or VGA monitor. Power through your workday, with three USB 3.0 (Type-A) ports with Fast-Charge support, SD and microSD card slots, and a Gigabit Ethernet port.
The universal USB Type-C multiport adapter (Thunderbolt 3 port compatible) offers enhanced productivity in the boardroom or classroom. Connect your laptop to one external monitor: 4K HDMI (3840 x 2160p @ 30Hz) or VGA (1920 x 1200 @ 60Hz).
With support for USB Power Delivery 3.0 (up to 85W), the USB-C multiport adapter lets you power and charge your laptop, and power your peripherals at the same time. PD 3.0 features Fast Role Swap to prevent USB data disruption when switching power sources (bus power and USB-C power adapter).
Connect your USB devices using the three USB 3.0 (Type-A) ports. Each USB port is a fast-charge and sync port, to ensure your tablet and smartphone are charged and ready. Each port offers 7.5W of charging power, with a combined total of 10W with all three ports in use.
Access the SD and microSD slots at the same time, and easily move data from one card to the other.
For mobile use, the USB-C adapter is bus-powered and lightweight, with a wraparound USB-C cable.
  • Connect to an external monitor
    The universal USB Type-C multiport adapter (Thunderbolt 3 port compatible) offers enhanced productivity in the boardroom or classroom. Connect your laptop to one external monitor: • 4K HDMI (3840 x 2160p @ 30Hz) or VGA (1920 x 1200 @ 60Hz)
  • Charge your laptop and peripherals
  • Connect USB devices
  • SD/microSD card access
  • Easy portability
    For mobile use, the USB-C adapter is bus-powered and lightweight, with a wraparound USB-C cable. DKT30CHVSCPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB C Multiport Adapter, USB Type-C Mini Dock with HDMI 4K or 1080p VGA Video, 100W PD Passthrough, 3x USB 3.0, Gigabit Ethernet, SD & MicroSD Card Reader, USB 3.0 Adapter - USB C HDMI Travel Dock (DKT30CHVSCPD) - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
7 cm x 12.2 cm x 1.4 cm
129 g
Gigabit Ethernet
3-year warranty
Docking station
7 cm
12.2 cm
1.4 cm
129 g
Enclosure Colour
Video
Max Resolution Details
3840 x 2160 - 30 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1, Power Delivery 3.0, Battery Charging 1.2
Expansion Slots
SD/microSD Memory Card
1 x USB-C 3.1 Gen 1 with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x display / video - HDMI - 19 pin HDMI Type A , 3 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB-C 3.1 Gen 1 - 24 pin USB-C
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 11.8 cm
USB powered, full duplex support, DisplayPort Alt Mode, 100W power delivery, auto MDIX support, plastic housing
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
137 g
