StarTech.com USB C 2.5 SATA Drive Enclosure
Quicklinx: CZCJWS00 Mfr#: S251BU31REMD
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
£36.71 ex VAT
£44.05 inc VAT
This USB 3.1 hard drive enclosure is a spare SATA drive enclosure for use with hot-swap hard drive bay for SATA SSD/HDD.
  • Add swappable storage capability
    This SATA to USB enclosure can be used as an extra hard drive enclosure for the hot-swap bay in order to provide multiple enclosures that can be swapped in and out of a main computer system. It's perfect for adding drives for backup rotations, and data recovery strategies.
  • Take your data with you
    If you need access to your data outside of the office, you can use the enclosure as a standard USB 3.1 enclosure - a powerful external storage solution when you need access to your files while you're on the road.
StarTech.com USB C Hard Drive Enclosure - 2.5 inch SSD HDD - works with S251BU31REM - Black Aluminum - USB 3.1 10Gbps - Height up to 9.5mm (S251BU31REMD) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
P/N: S251BU31REM
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM1351
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s
1 x USB 3.1 (Gen 2)
1 x USB-C to micro-USB cable - external , 1 x micro-USB to USB cable - external
USB powered, UASP transfer protocol, 2 LED indicators, TRIM support, tested with up to 2TB 7200 RPM hard drives
Mounting Kit
Included
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
10 - 90%
P/N: S251BU31REM
CZCJ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.17
CZCJ StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.09
CZCJ StarTech.com 4 Bay SSD/HDD Docking Station In Stock £145.83
HD Size: 2.5
Power Supply: [N/A]
