This USB 3.1 hard drive enclosure is a spare SATA drive enclosure for use with hot-swap hard drive bay for SATA SSD/HDD.
Add swappable storage capability
This SATA to USB enclosure can be used as an extra hard drive enclosure for the hot-swap bay in order to provide multiple enclosures that can be swapped in and out of a main computer system. It's perfect for adding drives for backup rotations, and data recovery strategies. -
Take your data with you
If you need access to your data outside of the office, you can use the enclosure as a standard USB 3.1 enclosure - a powerful external storage solution when you need access to your files while you're on the road.
- StarTech.com USB C Hard Drive Enclosure - 2.5 inch SSD HDD - works with S251BU31REM - Black Aluminum - USB 3.1 10Gbps - Height up to 9.5mm (S251BU31REMD) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- 2-year warranty
- Designed For
- P/N: S251BU31REM
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- ASMedia ASM1351
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 x USB 3.1 (Gen 2)
- Cables Included
- 1 x USB-C to micro-USB cable - external , 1 x micro-USB to USB cable - external
- USB powered, UASP transfer protocol, 2 LED indicators, TRIM support, tested with up to 2TB 7200 RPM hard drives
- Mounting Kit
- Included
- FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
- P/N: S251BU31REM
StarTech.com 2.5in USB 3.0 SSD SATA Hard Drive Enclosure | In Stock | £21.83 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £10.90 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £10.41 |
StarTech.com 4 Bay SSD/HDD Docking Station | In Stock | £144.99 |
