StarTech.com USB Bluetooth 5.3 Adapter
Quicklinx: J4L5WS00 Mfr#: AV53C1-USB-BLUETOOTH
38 In Stock
£18.00 ex VAT
£21.60 inc VAT
This Class 1 USB Bluetooth Adapter with EDR/BLE adds Bluetooth 5.3 capabilities to a laptop or desktop computer. This adapter enables a connection to multiple Bluetooth 5.3 peripherals, with data transfer rates of 2Mbps. The adapter supports a wireless connection with multiple devices, using minimal power consumption, at distances of up to 328ft (100m). This USB Bluetooth Adapter makes it easy to add Bluetooth capabilities and connect a wide range of wireless Bluetooth devices. The detachable, omni-directional antenna enhances range by transmitting a signal with higher power and receiving a signal with reduced noise/interference. This adapter supports A2DP (Advanced Audio Distribution Profile) for high-quality audio streaming to headphones and speakers, plus Bluetooth PAN (Personal Area Network) for wireless file sharing and internet tethering. It features Enhanced Data Rate (EDR) and Bluetooth Low Energy (BLE), for optimized battery efficiency. Plug-and-play installation for PCs/computers running Windows 7/8/10/11 or Linux with Kernel 5.19.0 and up ensures that installation and deployment is quick and straightforward. All these features are packed into a compact and unintrusive design.
  • Enhance Your Workstation
  • Seamless Connectivity
StarTech.com USB Bluetooth 5.3 Adapter for PC, Class 1, Windows/Linux - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.83 cm x 4.5 cm x 1 cm
22 g
Bluetooth 5.3, Bluetooth 5.3 EDR, Bluetooth 5.3 LE
Bluetooth Class
Class 1
Data Transfer Rate
2 Mbps
Realtek Semiconductor RTL8761BUE
Bluetooth 2.0, Bluetooth 3.0, Bluetooth 4.0
Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Linux Kernel 5.19 or later
Network adapter
External
USB 2.0
Wireless
Bluetooth Class
Class 1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Personal Area Networking Profile (PAN)
Data Transfer Rate
2 Mbps
Max Range Open Space
100 m
Status Indicators
USB powered
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
5 dBi
Processor / Memory
Plug and Play, RoHS, WEEE, FCC
1.83 cm
4.5 cm
1 cm
22 g
Shipping Width
20.3 cm
Shipping Depth
2.2 cm
Shipping Height
13 cm
Shipping Weight
70 g
-10 °C
50 °C
5 - 95% RH
