Duplicate or erase a USB flash drive or a SATA SSD/HDD, with 1:1 and cross-interface duplication. This versatile drive duplicator and eraser lets you clone and erase both USB-based storage devices and 2.5-inch and 3.5-inch SATA SSDs and HDDs, without having to connect to a computer. Ideal for IT professionals and system administrators, this versatile device helps you manage your file and data storage more efficiently, providing both 1:1 copying and cross-interface duplication.
As a drive cloner, this unit lets you easily copy SATA and USB drives without having to connect to a computer. It enables you to duplicate 1:1 (from SATA to SATA or USB to USB) as well as cross-interface duplication from SATA to USB or USB to SATA. The drive cloner provides four duplication modes, including Quick Copy, All Partitions, Sector-by-Sector (Whole Drive) at speeds of up to 6.6GB/min., and Percentage Copy.
Erase SATA or USB flash drives with ease, without a host computer. As a drive eraser, the SU2DUPERA11 gives you six erase modes including Quick Erase, Single Pass Overwrite (Full Erase), 3-Pass Overwrite (DoD) Erase, 3-Pass Overwrite and Compare, Secure Erase and 7-Pass Overwrite. You can erase a single SATA or USB drive, or two drives simultaneously.
The drive duplicator and eraser features a compact and lightweight design with easy-to-use features. It offers convenient menu navigation buttons and an LCD display that clearly identifies the active duplication or erase mode and task status, to ensure fast and efficient operation.
1:1 or cross-interface duplication of SATA or USB drives
As a drive cloner, this unit lets you easily copy SATA and USB drives without having to connect to a computer. It enables you to duplicate 1:1 (from SATA to SATA or USB to USB) as well as cross-interface duplication from SATA to USB or USB to SATA. The drive cloner provides four duplication modes, including Quick Copy, All Partitions, Sector-by-Sector (Whole Drive) at speeds of up to 6.6GB/min., and Percentage Copy. -
Multiple erase modes
Erase SATA or USB flash drives with ease, without a host computer. As a drive eraser, the SU2DUPERA11 gives you six erase modes including Quick Erase, Single Pass Overwrite (Full Erase), 3-Pass Overwrite (DoD) Erase, 3-Pass Overwrite and Compare, Secure Erase and 7-Pass Overwrite. You can erase a single SATA or USB drive, or two drives simultaneously. -
Designed for ease of use
The drive duplicator and eraser features a compact and lightweight design with easy-to-use features. It offers convenient menu navigation buttons and an LCD display that clearly identifies the active duplication or erase mode and task status, to ensure fast and efficient operation. The SU2DUPERA11 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Drive Duplicator & Eraser for USB Flash Drives & 2.5 / 3.5" SATA SSDs/HDDs- 1:1 duplication plus cross-interface - Standalone (SU2DUPERA11) - hard drive / USB drive duplicator
- Hard drive / USB drive duplicator
- Black
- Installed Devices / Modules Qty
- 1 (max)
- Supported Drives
- Serial ATA-600 / USB
- Localisation
- Japan, North America, United Kingdom, Europe
- Built-in Devices
- Status LCD
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- 9 cm x 13.5 cm x 2.9 cm
- 450 g
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- Supported Devices / Modules Qty
- 1
- Supported Drives
Storage Controller
- SATA (SATA 6Gb/s)
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Max Storage Devices Qty
- 1
Hard Drive
- No HDD
- 2 x USB - 4 pin USB Type A , 2 x SATA 6Gb/s - 22 pin Serial ATA
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 9 cm
- 13.5 cm
- 2.9 cm
- 450 g
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 5 - 95%
- Designed For
- P/N: SVA12M5NA
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.36 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.61 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £20.67 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.60 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £14.59 |
StarTech.com 12in 22 Pin SATA Power and Data Extension Cable | In Stock | £7.56 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser | In Stock | £116.33 |
StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps | In Stock | £83.05 |
StarTech.com USB 3.0 / eSATA 6-Bay Hard Drive Duplicator Dock - 1:5 HDD / SSD Cloner and Eraser | In Stock | £899.11 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.32 |
StarTech.com USB 3.0 Standalone Eraser Dock | In Stock | £210.44 |
StarTech.com SATA/SAS Duplicator & Eraser | In Stock | £1,128.94 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £681.14 |
