StarTech.com USB and SATA Cloner / Eraser
Quicklinx: CWSJWS00 Mfr#: SU2DUPERA11
£485.61 ex VAT
£582.73 inc VAT
Duplicate or erase a USB flash drive or a SATA SSD/HDD, with 1:1 and cross-interface duplication. This versatile drive duplicator and eraser lets you clone and erase both USB-based storage devices and 2.5-inch and 3.5-inch SATA SSDs and HDDs, without having to connect to a computer. Ideal for IT professionals and system administrators, this versatile device helps you manage your file and data storage more efficiently, providing both 1:1 copying and cross-interface duplication.
As a drive cloner, this unit lets you easily copy SATA and USB drives without having to connect to a computer. It enables you to duplicate 1:1 (from SATA to SATA or USB to USB) as well as cross-interface duplication from SATA to USB or USB to SATA. The drive cloner provides four duplication modes, including Quick Copy, All Partitions, Sector-by-Sector (Whole Drive) at speeds of up to 6.6GB/min., and Percentage Copy.
Erase SATA or USB flash drives with ease, without a host computer. As a drive eraser, the SU2DUPERA11 gives you six erase modes including Quick Erase, Single Pass Overwrite (Full Erase), 3-Pass Overwrite (DoD) Erase, 3-Pass Overwrite and Compare, Secure Erase and 7-Pass Overwrite. You can erase a single SATA or USB drive, or two drives simultaneously.
The drive duplicator and eraser features a compact and lightweight design with easy-to-use features. It offers convenient menu navigation buttons and an LCD display that clearly identifies the active duplication or erase mode and task status, to ensure fast and efficient operation.
  • 1:1 or cross-interface duplication of SATA or USB drives
  • Multiple erase modes
  • Designed for ease of use
    The drive duplicator and eraser features a compact and lightweight design with easy-to-use features. It offers convenient menu navigation buttons and an LCD display that clearly identifies the active duplication or erase mode and task status, to ensure fast and efficient operation. The SU2DUPERA11 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Drive Duplicator & Eraser for USB Flash Drives & 2.5 / 3.5" SATA SSDs/HDDs- 1:1 duplication plus cross-interface - Standalone (SU2DUPERA11) - hard drive / USB drive duplicator
Hard drive / USB drive duplicator
1 (max)
Supported Drives
Serial ATA-600 / USB
Japan, North America, United Kingdom, Europe
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
AC 120/230 V
9 cm x 13.5 cm x 2.9 cm
450 g
P/N: SVA12M5NA
Enclosure Colour
Chassis
Built-in Devices
Status LCD
Supported Devices / Modules Qty
1
Supported Drives
Storage Controller
SATA (SATA 6Gb/s)
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Max Storage Devices Qty
1
Hard Drive
No HDD
2 x USB - 4 pin USB Type A , 2 x SATA 6Gb/s - 22 pin Serial ATA
FCC, RoHS
External power adapter
AC 120/230 V
9 cm
13.5 cm
2.9 cm
450 g
5 °C
45 °C
5 - 95%
P/N: SVA12M5NA
CWSJ StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.59
CWSJ StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.99
CWSJ StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.89
CWSJ StarTech.com 12in 22 Pin SATA Power and Data Extension Cable In Stock £7.24
CWSJ StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £118.08
CWSJ StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £70.73
CWSJ StarTech.com 6in USB 3.0 Extension Cable In Stock £5.41
CWSJ StarTech.com SATA/SAS Duplicator & Eraser In Stock £1,026.33
CWSJ StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £691.38
