StarTech.com USB A to USB C Charging Cable
Quicklinx: GZ9FWS00 Mfr#: R2ACR-15C-USB-CABLE
Length: 15cm
13 In Stock
£6.10 ex VAT
£7.32 inc VAT
This rugged 6in (15cm) USB-A to right angle USB-C cable can be used to connect and/or charge a USB peripheral. Conveniently connect USB-C enabled devices at a right angle to the cable for organized cable routing solutions.
  • Built for Daily Use
    The durable USB charging cable features aramid fiber reinforcement that protects the cable from the stress of frequent bends. This allows the cable to flex without over-stretching or damaging the core components of the cable.
  • Flexible Strain Reliefs
    The USB cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been tested to withstand over 5,000+ bend cycles at a 180° angle.
  • Superior Connection Quality
    The durable cable supports all USB specifications up to USB 2.0, providing a dependable connection for all USB-A or USB-C peripheral devices. It supports up to 3A for charging USB-C or USB-A-enabled devices. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 6in (15cm) USB A to C Charging Cable Right Angle, Heavy Duty Fast Charge USB-C Cable, USB 2.0 A to Type-C, Durable and Rugged Aramid Fiber, 3A, S20/iPad/Pixel - High Quality Short USB Charging Cord (R2ACR-15C-USB-CABLE) - USB-C cable - USB to 24 pin USB-C - 15 cm
USB-C cable
Shielded
Sync and charge, strain relief, halogen free, heavy duty, up to 60 Watts of power delivery, Quick Charge
Length
15 cm
Connector
4 pin USB Type A - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
Rated Current
3 A
Thunderbolt 3 / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/32
Rated Current
3 A
Plated Connector
Gold, nickel
Length
15 cm
Outside Diameter
3.1 mm
10 g
Connector
Thunderbolt 3 / USB 2.0, RoHS, WEEE, EMI
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
3 cm
GZ9F StarTech.com 3ft USB A to USB C Charging Cable In Stock £6.94
GZ9F StarTech.com 6ft USB A to USB C Charging Cable In Stock £7.69
GZ9F StarTech.com 6in USB C Charging Cable In Stock £6.38
GZ9F StarTech.com 3ft USB C Charging Cable In Stock £8.53
GZ9F StarTech.com 6ft USB C Charging Cable In Stock £9.90
GZ9F StarTech.com 1ft USB C Charging Cable In Stock £7.44
Length: 15cm
