This rugged 6in (15cm) USB-A to right angle USB-C cable can be used to connect and/or charge a USB peripheral. Conveniently connect USB-C enabled devices at a right angle to the cable for organized cable routing solutions.
                Built for Daily UseThe durable USB charging cable features aramid fiber reinforcement that protects the cable from the stress of frequent bends. This allows the cable to flex without over-stretching or damaging the core components of the cable.
                Flexible Strain ReliefsThe USB cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been tested to withstand over 5,000+ bend cycles at a 180° angle.
                Superior Connection QualityThe durable cable supports all USB specifications up to USB 2.0, providing a dependable connection for all USB-A or USB-C peripheral devices. It supports up to 3A for charging USB-C or USB-A-enabled devices. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 6in (15cm) USB A to C Charging Cable Right Angle, Heavy Duty Fast Charge USB-C Cable, USB 2.0 A to Type-C, Durable and Rugged Aramid Fiber, 3A, S20/iPad/Pixel - High Quality Short USB Charging Cord (R2ACR-15C-USB-CABLE) - USB-C cable - USB to 24 pin USB-C - 15 cm
- USB-C cable
- Technology
- Shielded
- Sync and charge, strain relief, halogen free, heavy duty, up to 60 Watts of power delivery, Quick Charge
- Length
- 15 cm
- Connector
- 4 pin USB Type A - male - straight
- Connector (Second End)
- 24 pin USB-C - male - right-angled
- Rated Current
- 3 A
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/32
- Rated Current
- 3 A
- Plated Connector
- Gold, nickel
- Length
- 15 cm
- Outside Diameter
- 3.1 mm
- Black
- 10 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, WEEE, EMI
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 3 cm
|  | StarTech.com 3ft USB A to USB C Charging Cable | In Stock | £6.94 |
|  | StarTech.com 6ft USB A to USB C Charging Cable | In Stock | £7.83 |
|  | StarTech.com 6in USB C Charging Cable | In Stock | £6.38 |
|  | StarTech.com 3ft USB C Charging Cable | In Stock | £8.19 |
|  | StarTech.com 6ft USB C Charging Cable | In Stock | £8.70 |
|  | StarTech.com 1ft USB C Charging Cable | In Stock | £6.63 |
