This 20in (50cm) coiled USB A to USB C cable can withstand the daily demands of charging and syncing your mobile devices. It contracts to 12in (32cm) making it compact and convenient to store.
                Built for Daily UseThe durable USB A to USB C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
                Flexible Strain ReliefThe USB A to USB C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 5,000+ bend cycles at a 180° angle.
                Superior ConnectionThe durable cable supports all USB 2.0 specifications providing a dependable connection for all your USB-C devices. It supports up to 3A for charging your USB C compatible devices. R2ACC-50C-USB-CABLE is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 20in (50cm) USB A to C Charging Cable, Coiled Heavy Duty Fast Charge & Sync USB-C Cable, High Quality USB 2.0 A to Type-C, Rugged Aramid Fiber, TPE, 3A, S20, iPad, Pixel - Durable Male to Male USB - USB-C cable - USB to 24 pin USB-C - 50 cm
- USB-C cable
- Technology
- Shielded
- Coiled, sync and charge, halogen free, Quick Charge
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/32
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 50 cm
- Outside Diameter
- 3.1 mm
- Black
- 38 g
- Connector
- USB / USB 2.0, RoHS, WEEE, EMI
