StarTech.com USB A to C Charging Cable
Quicklinx: GPKYWS00 Mfr#: R2ACC-1M-USB-CABLE
Length: 1m
Hurry, only 1 left in stock!
£9.97 ex VAT
£11.96 inc VAT
This 3.3ft (1m) coiled USB A to USB C cable can withstand the daily demands of charging and syncing your mobile devices. It contracts to 1.2ft (36.6cm) making it compact and convenient to store.
  • Built for Daily Use
    The durable USB A to USB C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
  • Flexible Strain Relief
    The USB A to USB C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 5,000+ bend cycles at a 180° angle.
  • Superior Connection
    The durable cable supports all USB 2.0 specifications providing a dependable connection for all your USB-C devices. It supports up to 3A for charging your USB C compatible devices. R2ACC-1M-USB-CABLE is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 3ft (1m) USB A to C Charging Cable, Coiled Heavy Duty Fast Charge & Sync USB-C Cable, High Quality USB 2.0 A to Type-C, Rugged Aramid Fiber, TPE, 3A, S20, iPad, Pixel - Durable Male to Male USB, Black - USB-C cable - USB to 24 pin USB-C - 1 m
USB-C cable
Shielded
Coiled, sync and charge, halogen free, Quick Charge
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/32
Rated Current
3 A
Plated Connector
Nickel
Length
1 m
Outside Diameter
3.1 mm
38 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE, EMI
Length: 1m
