StarTech.com USB 802.11N Dual Band Wireless Network Adapter 300 Mbps High Power 2T2R Wi-Fi 2.4/5GHz
Quicklinx: 8G5ZWS00 Mfr#: USB300WN2X2D
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
Add high-powered, dual band Wireless-N connectivity, with extended range to a desktop or laptop through USB. The USB300WN2X2D dual-band Wireless-N USB Network Adapter allows a USB-enabled computer to connect to a WiFi network on the 2.4GHz or 5GHz frequency. The adapter can be used for connecting to Wireless-A, B, G or N networks, and features dual 5dBi high gain antennas, as well as powered amplifiers to ensure optimized reception capable of supporting up to 300Mbps of data bandwidth over distances up to 3 times greater than a standard WiFi adapter.
This versatile dual band network adapter features a 2T2R (2 transmitter, 2 receiver), Multiple Input/Multiple Output (MIMO) design, and can connect to older wireless access points (that may only operate on a 2.4GHz frequeny), as well as newer WAPs that support the less congested 5 GHz range.
The USB300WN2X2D is designed to provide a dependable, long-lasting wireless access solution.
StarTech.com USB 802.11N Dual Band Wireless Network Adapter - 300 Mbps High Power 2T2R Wi-Fi 2.4/5GHz - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
5.6 cm x 8.8 cm x 1.8 cm
35 g
802.11a, 802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Ralink RT3572L
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Linux Kernel 2.6.32, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
P/N: R150WN1X1T
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
WMM support, QoS, WPS, 2T2R MIMO technology
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
5 dBi
Processor / Memory
Ralink RT3572L
1 x USB 2.0 - 5 pin Micro-USB Type B
1 x USB extension cable (external)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
FCC, RoHS
Software Included
Drivers & Utilities
5.6 cm
8.8 cm
1.8 cm
35 g
60 °C
10 - 90%
P/N: R150WN1X1T
