StarTech.com USB 3 to HDMI w/ USB Hub
Quicklinx: 8NV9WS00 Mfr#: USB32HDEH
10 In Stock
£22.24 ex VAT
£26.68 inc VAT
Connect an HDMI-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32HDEH USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output port with 1920x1200/1080p video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the HDMI adapter - an ideal workaround for Ultrabook or laptop users, where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity. The included HDMI to DVI adapter also allows you to use this device with a DVI display.
StarTech.com USB 3.0 to HDMI & DVI Adapter with 1x USB Port - External Video & Graphics Card Adapter - Dual Monitor Hub - Supports Windows (USB32HDEH) - docking station - USB 3.0 - HDMI - TAA Compliant
Docking station
Docking Interface
USB 3.0
Video Interfaces
HDMI
4.9 cm x 8.5 cm x 1.7 cm
66 g
TAA Compliant
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Docking station
4.9 cm
8.5 cm
1.7 cm
66 g
Enclosure Colour
Video
Max Resolution Details
1920 x 1200
USB 2.0, USB 3.0
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
1 x USB cable - integrated - 16 cm , 1 x HDMI-DVI adapter - external
USB powered
FCC, RoHS
TAA Compliant
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 (32/64 bits)
Shipping Width
14.6 cm
Shipping Depth
21.3 cm
Shipping Height
3.8 cm
Shipping Weight
244 g
8NV9 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
8NV9 StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £42.49
8NV9 StarTech.com USB 3 to HDMI w/ USB Hub In Stock £22.24
8NV9 StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £22.93
8NV9 StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £47.72
8NV9 StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £35.15
8NV9 StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £78.39
