StarTech.com USB 3 Encrypted HDD Enclosure
Quicklinx: B4HSWS00 Mfr#: S2510BU33PW
Turn a 6 Gbps HDD or SSD into secure external storage with touchpad password entry. The S2510BU33PW USB 3.0 encrypted hard drive enclosure lets you to turn your 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an AES-encrypted external drive.
To ensure all of the data on your drive is protected from unauthorized access, the secure enclosure uses an Advanced Encryption Standard Algorithm (256-bit AES). Once your encryption is set, access to the content is only authorized through a customized PIN that you set and enter using the sleek built-in touchpad. The encryption is hardware based, eliminating the hassle of complicated software installation and configuration.
The hard drive enclosure ensures maximum performance, with support for USB 3.0 transfer speeds up to 5 Gbps. The enclosure also supports SATA III drives, ensuring you can still achieve high performance while accessing your SATA 6 Gbps SSD externally.
StarTech.com USB 3.0 Hard Drive Enclosure - Encrypted SATA Hard Drive to USB - HDD/SSD Enclosure with Password Protection (S2510BU33PW) - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Plastic, steel
7.7 cm x 12.3 cm x 1.4 cm
94 g
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.0
Product Material
Plastic, steel
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type A
Carrying case, screwdriver, screws
1 x USB cable - external
USB powered, status OLED display, tested with up to 1TB 5400 RPM hard drives, touchpad
Plug and Play, AES-256
7.7 cm
12.3 cm
1.4 cm
94 g
B4HS StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
B4HS StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £8.46
B4HS StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
B4HS StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.89
B4HS StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.39
B4HS StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £12.79
B4HS StarTech.com Rugged Hard Drive Enclosure In Stock £32.49
B4HS StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
B4HS StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA In Stock £49.25
