StarTech.com USB 3.1 Rugged Drive Enclosure
Quicklinx: D9KNWS00 Mfr#: S251BRU31C3
This USB 3.1 external hard drive enclosure offers a rugged, high-performance solution for accessing and backing up your important files, while protecting your drive in harsh environments. It comes with two cables, to support both USB-C and USB-A enabled laptops and tablets.
  • Maximize the performance of your 2.5" SATA drives
    The drive enclosure delivers USB 3.1 Gen 2 performance with data transfer speeds of up to 10 Gbps, letting you leverage the high performance of the latest drives while alleviating bottlenecks in your data transfers. With support for SATA I, II, and III, and high-capacity drives, this USB-C enclosure is compatible with virtually any 2.5" SATA SSD or HDD.
  • IP65 rated for water and dust resistance
    Be prepared for the unexpected when you're out in the field, in outdoor or industrial environments. The rugged hard drive enclosure provides superior water and dust resistance with an IP65 rating, to keep your data safe and secure, even in sudden downpours or dust storms.
  • Military-rated protection
    The rugged enclosure is military rated to protect your drive against environmental hazards such as drops, shock and vibration. The tough-wearing exterior casing provides shock resistance, while the flexible silicone sleeve provides extra protection, absorbing the impact of bumps, rough baggage handling or drops. Inside, an extra layer of silicone provides drive stability.
StarTech.com 2.5" SATA SSD/HDD Hard Drive Enclosure - USB 3.1 (10Gbps) External Hard Drive Case - IP65-Rated Enclosure (S251BRU31C3) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Power Source
USB bus
11.2 cm x 14.6 cm x 3 cm
200 g
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM235CM
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
1 x USB-C to USB-A cable - external , 1 x USB-C cable - external
USB powered, rugged, tested with up to 2TB 7200 RPM 2.5" hard drives, S.M.A.R.T. support, TRIM support
MTBF
48000 hours
FCC, RoHS, MIL-STD 810G, WEEE, UASP (USB Attached SCSI Protocol)
Power Source
USB bus
11.2 cm
14.6 cm
3 cm
200 g
-40 °C
85 °C
20 - 95%
D9KN StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.90
D9KN StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £10.18
D9KN StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
D9KN StarTech.com M.2 SATA Enclosure with USB-C In Stock £26.26
D9KN StarTech.com Dual M.2 Enclosure - RAID In Stock £43.59
D9KN StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.23
D9KN StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £14.70
D9KN StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £9.39
D9KN StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA In Stock £50.65
