Turn your mSATA or mSATA Mini drive into a portable, high performance storage solution over USB 3.1 Gen 2. Add high-speed data storage to your laptop or desktop computer, with this portable mSATA and mSATA Mini drive enclosure. It gives you fast data transfer speeds with USB 3.1 (10Gbps) in a solid aluminum enclosure.
With its compact design and metal housing, the mSATA drive enclosure gives you a highly portable, high-speed storage solution. Slim and stylish, the enclosure makes the ideal accessory for laptop or desktop computers.
The mSATA enclosure provides dependable drive protection with its durable, solid aluminum housing. It also features ventilation holes to help protect your drive from overheating by allowing heat to dissipate and help maintain an optimum operating temperature.
With support for USB 3.1 (also known as USB 3.1 Gen 2) and SATA III (6Gbps) host connections, the drive enclosure lets you maximize the performance of your mSATA solid-state drives to achieve greater data transfer speeds. The mSATA drive enclosure also supports UASP for enhanced performance.
This portable drive enclosure is compatible with all standard mSATA drives, including the mSATA Mini (Half-Size) form factor.
- StarTech.com USB 3.1 Gen 2 (10Gbps) Enclosure - Portable mSATA SSD Enclosure - Aluminum mSATA Drive Enclosure with UASP (SMS1BMU313) - storage enclosure - SATA 6Gb/s / mSATA - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Black, silver
- Expansion Bays
- 1 x internal - mSATA
- Hard Drive Form Factor Compatibility
- mSATA, mSATA mini
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- USB bus
- 4.15 cm x 9.85 cm x 1.2 cm
- 55 g
- 2-year warranty
- mSATA, mSATA mini
- Hard Drive Maximum Height
- 50.8 mm
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
- Black, silver
Storage Controller
- Interface
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Processor
- ASMedia ASM1351
- Bays
- 1 x mSATA - mSATA (internal)
- Connections
- 1 x USB 3.1 (Gen 2) - 9 pin Micro-USB Type B
- Included Accessories
- Screwdriver, 4 x screws
- Cables Included
- 1 x micro-USB to USB cable - external
- LED indicator, UASP transfer protocol, ventilation holes, tested with up to 1TB mSATA drives
- FCC, RoHS, WEEE, RCM
- Power Source
- USB bus
- Limited warranty - 2 years
- 4.15 cm
- 9.85 cm
- 1.2 cm
- 55 g
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £8.16 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.62 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £27.64 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £86.59 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £27.06 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £19.63 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £135.47 |
