StarTech.com USB 3.1 Gen 2 Single-bay Dock
Quicklinx: BGBZWS00 Mfr#: SDOCKU313
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: Power adapter
12 In Stock
£53.41 ex VAT
£64.09 inc VAT
Dock your 2.5" or 3.5" SATA drive over high performance USB 3.1 with UASP. Unleash the power of USB 3.1 Gen 2 (10 Gbps) with this single-drive docking station. It supports both 2.5" and 3.5" form factors for solid-state and hard drives, with a high drive capacity of 6TB.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
It's never been easier to dock and swap drives from your desktop computer or laptop. Simply insert your drives into the top loading slot, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance.
  • Efficient hot-swap capability
    The docking station enables users to exchange drives on the fly, minimizing downtime during data management and enhancing productivity.
  • High-speed data transfer
    With USB 3.1 (Gen 2) and UASP transfer protocol, this dock provides faster data speeds, allowing for quick and efficient file transfers.
  • Versatile hard drive compatibility
    The device supports both 2.5" and 3.5" hard drives, accommodating a wide range of storage solutions for various needs.
  • Clear operational indicators
    Equipped with LED indicators for data and power, users can easily monitor the status of the docking station and connected drives.
  • Reliable build quality
    Constructed from durable plastic, this docking station is designed to withstand regular use while maintaining performance.
StarTech.com USB 3.1 (10Gbps) Single-Bay Dock for 2.5"/3.5" SATA SSD/HDD - USB 3.1 Hard Drive Docking Station with UASP (SDOCKU313) - storage controller - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Data indicator, power indicator
Supported Devices
Hard drive, solid state drive
Product Material
Plastic
AC 120/230 V
9.3 cm x 14.5 cm x 6.52 cm
400 g
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
Supported Devices
ASMedia ASM1351
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
1 x USB cable - external , 4 x power connector adaptor - external
LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
FCC, RoHS
Power adapter
AC 120/230 V
9.3 cm
14.5 cm
6.52 cm
400 g
5 °C
35 °C
20 - 80%
BGBZ StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
BGBZ StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.99
BGBZ StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.52
BGBZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.07
BGBZ StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.17
BGBZ StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.80
BGBZ StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.90
BGBZ StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.41
BGBZ StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £84.45
BGBZ StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.20
BGBZ StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £18.44
BGBZ StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £28.00
BGBZ StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £55.00
BGBZ StarTech.com USB C to SATA Adapter Cable In Stock £36.11
BGBZ StarTech.com 4 Bay SSD/HDD Docking Station In Stock £144.99
HD Size: 2.5
HD Size: 3.5
