The high-speed, high-capacity data storage solution you've been waiting for - with USB 3.1 Gen 2. Now, get the speed and capacity you want in external data storage. This single-drive enclosure for 3.5" SATA hard drives gives you high-speed USB 3.1 Gen 2 (10 Gbps) performance with a large drive capacity of up to 6TB.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSHDs and hard drives, while alleviating bottlenecks in your data transfers.
The clean and simple design makes this enclosure the perfect desktop companion for your Mac or PC. It's made of durable aluminum with a fan-less design that ensures quiet operation. It also comes with a vertical stand so it occupies minimal space in your work area.
This versatile enclosure comes with a USB Type A-to-B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
- StarTech.com USB 3.1 Gen 2 External Hard Drive Enclosure for 3.5" SATA Drives - Fan-less UASP Enhanced Single Drive Enclosure (S351BU313) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 10 GBps
- Supported Devices
- Hard drive
- Product Material
- Aluminium
- Power Source
- USB bus
- 7.7 cm x 12 cm x 1.55 cm
- 130 g
- 2-year warranty
- Designed For
- P/N: BNDTBUSB3142, HB30C3A1CFB, HB30C3A1CFS, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V
- 3.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 10 GBps
- Supported Devices
- Hard drive
- Processor
- ASMedia ASM1351 ASM1351
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 9 pin USB Type B
- Included Accessories
- Screwdriver, 4 x screws
- Cables Included
- 1 x USB cable - external
- LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
- FCC, RoHS
- Power Source
- USB bus
- Limited warranty - 2 years
- 7.7 cm
- 12 cm
- 1.55 cm
- 130 g
- 0 °C
- 40 °C
- 5 - 95%
- Designed For
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £5.12 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.21 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £24.93 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £43.55 |
StarTech.com USB 3.1 Tool-free Enclosure | In Stock | £20.73 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £70.56 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £13.80 |
StarTech.com USB 3.1 Gen 2 Enclosure | In Stock | £36.34 |
