StarTech.com USB 3.1 Enclosure with USB-C
Quicklinx: BZN1WS00 Mfr#: S251BPU31C3
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
20 In Stock
£25.00 ex VAT
£30.00 inc VAT
Add fast and portable data storage to your USB Type-C enabled MacBook, Chromebook Pixel, or laptop. Take your valuable data with you wherever you go. This single drive enclosure for 2.5" SSDs/HDDs lets you utilize the USB-C port on your MacBook, Chromebook Pixel, Dell Latitude 11 5000 Series 2-in-1, or other device to add ultra-fast, ultra-portable data storage.
The enclosure's compact design and lightweight construction provides a highly portable solution for adding external data storage to any device with USB-C . It tucks easily into a laptop bag or carrying case for portable storage, and it's completely tool-free so you can install your drives quickly on the fly. The enclosure is powered directly from the USB port, with no external power required, so there's no need to carry along an adapter.
The drive enclosure comes with a USB-C to Micro B cable. The USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the USB-C plug quickly with either side facing up, which means less risk of damaging your ports and less frustration.
With support for SATA I, II and III and large capacity drives (tested with hard drives up to 2TB), this USB-C enclosure is compatible with virtually any 2.5in. SATA hard drive or solid-state drive. The enclosure delivers USB 3.1 Gen 2 performance with data transfer speeds of up to 10Gbps, letting you leverage the high performance of the latest SSDs and hard drives while alleviating bottlenecks in your data transfers. It's also enhanced with UASP, which increases read and write speeds, to utilize the full potential of your SATA III drives.
USB 3.1 gives you greater bandwidth and speed with file transfer rates of up to 10Gbps - twice the capability of USB 3.0 technology.
StarTech.com USB 3.1 (10Gbps) Type-C Enclosure - Tool-Free Enclosure - External Hard Drive Enclosure for 2.5in SATA SSD/HDD (S251BPU31C3) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Plastic
Power Source
USB bus
8.8 cm x 13.2 cm x 1.5 cm
74 g
2.5"
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
1
ASMedia ASM1351
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
USB (power) cable, HDD pad
1 x USB cable - external
LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
FCC, RoHS, WEEE
Power Source
USB bus
8.8 cm
13.2 cm
1.5 cm
74 g
5 - 90%
BZN1 StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £23.45
BZN1 StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD In Stock £17.91
BZN1 StarTech.com Rugged Hard Drive Enclosure In Stock £35.75
BZN1 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £29.35
BZN1 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.37
BZN1 StarTech.com USB 3.1 Tool-free Enclosure In Stock £25.00
BZN1 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.01
BZN1 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £18.74
BZN1 StarTech.com USB 3.1 Enclosure with USB-C In Stock £25.00
BZN1 StarTech.com USB 3.1 2.5 SATA Enclosure USB-C USB-A In Stock £32.26
BZN1 StarTech.com Dual M.2 Enclosure - RAID In Stock £47.71
BZN1 StarTech.com 4 Bay SSD/HDD Docking Station In Stock £144.99
BZN1 StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA In Stock £64.78
HD Size: 2.5
Power Supply: [N/A]
