Get ultra-fast access to data by connecting a 2.5" SATA SSD/HDD to your laptop's USB-C port. Take advantage of the USB-C port on the latest MacBook, Chromebook Pixel or other laptop to get quick external drive access. This cable-style adapter lets you use the USB Type-C port to connect your laptop directly to a 2.5" solid-state or hard drive and access it through ultra-fast USB 3.1 Gen. 2 (10 Gbps). It's fast and easy to connect to your SATA drives, with no additional accessories required.
Use this cable-style adapter, wherever you go, to access valuable data quickly - it's USB powered so there's no external power required. It features a compact, lightweight design that tucks easily into a laptop bag or carrying case.
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD or HDD quickly. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
Efficient data transfer
With a data transfer rate of 6 Gbit/s, this adapter facilitates quick file transfers between your SATA drives and USB-C devices. -
Broad compatibility
This adapter is compatible with both 2.5'' and 3.5'' SATA drives, allowing a versatile solution for different storage needs. -
Simple setup
The integrated USB cable design eliminates the hassle of multiple cables, making it easy to connect and disconnect as needed. -
High-speed interface
Supported by USB 3.1 (Gen 2), this adapter ensures optimal performance for accessing and transferring data. -
Mac compatibility
Designed for Mac users, this adapter ensures seamless connectivity without additional drivers.
- StarTech.com USB C to SATA Adapter - External Hard Drive Connector for 2.5'' SATA Drives - SATA SSD / HDD to USB C Cable (USB31CSAT3CB) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- 4.3 cm x 50.8 cm x 5 mm
- 29.2 g
- 2-year warranty
- 2.5", 3.5"
- Host Bus
- USB 3.1 (Gen 2)
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 24 pin USB-C
- Cables Included
- 1 x USB cable - integrated
- Limited warranty - 2 years
- 4.3 cm
- 50.8 cm
- 5 mm
- 29.2 g
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.30 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.07 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.04 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.52 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £17.99 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £12.50 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £16.51 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £9.01 |
StarTech.com CFast Card Reader - USB 3.0 | In Stock | £22.18 |
StarTech.com CFast Card Reader - USB-C | In Stock | £28.14 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £25.24 |
