StarTech.com USB 3.1 Adapter Cable w/ USB-C
Quicklinx: BL71WS00 Mfr#: USB31CSAT3CB
Hurry, only 2 left in stock!
£17.50 ex VAT
£21.00 inc VAT
Express delivery Delivered on Tuesday
Get ultra-fast access to data by connecting a 2.5" SATA SSD/HDD to your laptop's USB-C port. Take advantage of the USB-C port on the latest MacBook, Chromebook Pixel or other laptop to get quick external drive access. This cable-style adapter lets you use the USB Type-C port to connect your laptop directly to a 2.5" solid-state or hard drive and access it through ultra-fast USB 3.1 Gen. 2 (10 Gbps). It's fast and easy to connect to your SATA drives, with no additional accessories required.
Use this cable-style adapter, wherever you go, to access valuable data quickly - it's USB powered so there's no external power required. It features a compact, lightweight design that tucks easily into a laptop bag or carrying case.
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD or HDD quickly. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
StarTech.com USB C to SATA Adapter - External Hard Drive Connector for 2.5" SATA Drives - SATA SSD / HDD to USB C Cable (USB31CSAT3CB) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive, solid state drive
4.3 cm x 50.8 cm x 5 mm
29.2 g
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
1 x USB cable - integrated
4.3 cm
50.8 cm
5 mm
29.2 g
BL71 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.92
BL71 StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD In Stock £22.35
BL71 StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter In Stock £32.88
BL71 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £9.90
BL71 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £17.61
BL71 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £17.66
BL71 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.42
BL71 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.50
Stock Status: In stock
